Just a heads up to all the other 2019 owners out there.  Last night I noticed water on the top on the back seat on the passenger side and my rear window is leaking.  It looks to be coming from the area around the sliding window rail.  I spoke with the dealership last night and will be dropping it off today for them to fix.  I'm not really pissed off about it because this is the kind of stuff that happens when you buy the first model year of a new design but I just wanted to give you guys a heads up on something to look out for.
That sucks but if you ask me this shouldn't be expected. A window leak should never happen on a new vehicle. Its not like this is the first trucks they ever built and they had this problem on the last models.
  • Like 4
I too am a disappointed owner of a 2019 GMC Sierra 1500 Denali. Have had the truck about a month with 2K miles and the rear window leaking as well in the upper right corner. Headliner needs to be replaced and the minimum wait from factory is 2 weeks?!?! Didn’t notice the leak until a trip back from Atlanta in extremely heavy rain. How long had this thing been leaking? Probably from the start. I agree with the previous post, this should not be an issue an owner should have to deal with on a brand new truck, regardless of purchase price. Seems to me a water tight interior is a fundamental requisite for any vehicle. Poor quality control GM, hope you fix this issue at factory by recalibration of the robot that applies the sealant. Hope this is the only QC issue but I can’t help being dubious at this point.
Edited by JKD
I would want my vehicle replaced if I found out it was leaking. Knowing that the interior got soaked would ruin my ownership experience.
My sentiment exactly. That’s what I have requested and GM has yet to acknowledge. It makes me think this issue is more prevalent than we yet know. I’m afraid there will be a lot of unhappy owners dealing with this same issue. Thankfully, the dealership is top notch. Not sure if I can mention the name on this forum, but they deserve the business.
I remember my dads 81' F150 leaking from the quarter window and watching it trickle down the door onto the rubber floor and not effecting anything. These new trucks are disasters waiting to happen in so many ways.
  • Confused 1
  • Sad 1
I probably should have given more details but the interior didn't get soaked, it was just dripping in and I don't think it even got the carpet wet.  There was water on the top of the back seat and I just wiped it off.  Of course this should still not happen and needs to be fixed but there was no damage done to the interior.
It is the nature of the beast.
2019 T1 GM trucks have the same sliding unit as the K2 current/outgoing platform.
My '14 sierra slider does not "leak" , but rather water gets in at car washes on occasion. Just enough to sprinkle the rear seat top.
Especially if you use the want and spray at an angle from the side.
Other than that rain and normal wet conditions do not produce any leaking.
My neighbor has an F150 and his slider does the same thing.
A good friend of mine has a new RAM 1500 and his also lets water in at the car wash.
It wasn't leaking at the rail for the window, that was the first place I looked.  I appears to be coming in from the top of the window and was leaking while it was raining.  Again, not a huge amount of water but enough that it needs to be fixed.  The dealership said it looks like the seal was not installed correctly.
I got the same diagnosis from my dealer. It’s not leaking from the split window, but rather from the top passenger side of the glass itself. Bad window seal. Not sure if GM uses the butyl rubber or an elastomeric sealant, but this is definitely a factory defect. BTW, I’m sure we can all agree that any window that opens has the potential to leak if enough water pressure applied. However, a fixed window should not leak and each vehicle should be tested before rolling out the factory door...in my humble opinion.
Absolutely a sliding window has the potential to leak.  I agree that a fixed window should not leak but it does happen.  Now if this becomes a common thing then Chevy really has an issue that needs to be addressed.
Agreed. Both of us have brand new trucks about a month old with the same problem in the same place. Time will tell how prevalent the issue is as hopefully others find this post and share their experience.
In that case, watch out when you head to the car wash with the slider! :thumbs:
I have learned to just keep the wand away from that area at full pressure.
Thanks Sierra Dan, I hand wash and wax my truck once a week. Has never seen a car wash which may explain why the leak wasn’t detected earlier. Sold my 2 year old Canyon for $$$$$, still looked like it just came of the showroom floor.
I hand wash also, but use the want to soak the truck down first to remove any light dust.
Black is not great for auto car washes! LOL
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,253 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
