Thanks for update.  I held off on a 2” level kit front and back wanting a 4”.  The 6” is available now but not the 4”.  What size lift is rough country saying they are about to get done. 4” ?
Update.  I believe the guys I am working with locally are using pro comp lifts
23 hours ago, Jason Payne said:
I called Rough Country today and they told me they were a few weeks out on the Adaptive Ride Control?    I”m driving a 2018 stock Denali now but wanted to do lift, wheels, and tires immediately when I get My 2019 in a few days?   Any pics or what size tires anybody else running?
What size lift are you looking at? You need a level on a non Trailboss to run 33x12s with 0 mm offset.  You need a 4 inch lift to run 35x12s with 0 mm offset.  If you want to run 35x12s with any negative offset such as -22 or -44, you will need at least a 6 inch lift
I was thinking 3" front and 1.5" back with 295 or 305  tires and don't know if 18 or 20" wheels?   I want to look good but do not want to sacrifice anything on ride.   Somebody said on this thread that rough country already did a lift for ARC for them but they told me it wasn"t ready yet?   Also has anybody done Flowmaster or Borla exhaust on the 2019 6.2 yet?
Jason - I have the same desire as you.  I want to keep all the comfort and quality I paid for with the 2019 ride while at the same time giving it a much needed lift without going too high.
To everyone: What lift kit brand does everyone prefer.  I live in GA and the guys at the local shop I think are wanting to do Pro Comp.  I am not familiar with a lot of brands.  One of the guys there told me they would need to lift the back and front because the truck was already level but I do not believe that was correct as you all have confirmed and someone else at the shop that does design work said the front needed to come up more.
I have been told that 6" lifts are officially tested and approved for this truck AND level kits are good too but that 4" lifts are still being designed.  I am assuming this is from Pro Comp but not sure.  I have called several suppliers but all of them seem to be not ready.
My guess is that anyone getting a lift other than 6" is likely getting something that is custom made on the spot or a work around with current parts.  I am want to make sure whatever I put on the truck keeps everything working like stock.
Any thoughts on directions I should head or recommendations, would be appreciated.
Found out that Fabtech has a 3.5” lift for Denali w/ ARC.   Anybody used it?
Hmmm.. Doesn’t look to promising at this point in time. I think I’m going to do the suspension max from 16-18. It has the bracket for the sensors and level it out. I’m researching the difference between magna and ARC.. I read where someone used a Rough Country and no problems[emoji3166]
On 11/19/2018 at 5:13 PM, Brad TN said:
Hey folks,
I just bought a '19 Sierra Denali crew cab 4 x 4 with Adaptive Ride Control. I want to add a 1.5" or 2" spacer to the front in order to make the truck sit level.
 Internet reading and a couple of lift kit tech guys suggest that there may be some programming necessary after a kit is installed. Others say it is not. Has anyone done this that can give me a firsthand report on what kit you installed, and what exactly is involved?
Thanks,
Brad
This is mine with a “2 in front and 1” in back
I have had no problems with the Rough Country 2" front level kit. I recommend it 100%. I'm running a 305-50/20 tire. 0 offset wheels... We did have to trim inside the wheelwell, and cut the front mudflap for turn clearance...
Im looking for a lift kit, or leveling kit as well. I appreciate all the info available here. Can anyone posts more pics of theirs after install?
The difference between the Denali and Chevrolet suspension is the ARC component.  2019 Denali requires an extension of the rod which is approximately 3/4 of an inch for a front level kit.  Rough country has them now and you can see them online.  You will have to do the same to the rear (extension) should you want to lift it also.  Other option is to replace the shocks.  These are not electronic “magnaride” but fully mechanical and controlled by the rod based on suspension travel.  You can measure the rod in stock state and then with the lift added.  The difference is the additional length you will need to make a bracket for,  to add to the rod length.  I did this on mine and just ordered the Chevrolet leveling kit.  The GMC was almost twice the price for the two, approximately 3/4 inch extensions, two lock nuts and two bolts.
We added the wedge below the shock at the bottom where it mounts to the arm and added a 1” block between the leaf spring and axle. If has changed my ride I can’t tell it.
It will change the ride.  While I am not sure if it places it in a firmer or softer position, changing the length of the rod will change the damping characteristics of the shock.  It stands to reason that the more the suspension compresses, the firmer the damping would become so as to make the shock progressively stiffer.  Without it damping would remain in a linear state, unless valuing in the shock is designed to change based on travel on its own (which there wouldn’t be a need for the rod then.).  That is how the Denali system is designed to work.  If there is no increase in your arm length, you will be riding in a deeper portion of the damping, and despite “not feeling it” it should be stiffer.  It may be subtle enough that the change is not detectable except under certain circumstances.
Let’s just say I haven’t noticed a difference. Very seldom do I dial it from Touring to Sport. It never goes off road and don’t  have any intentions of taking it off road. Never going to pull anything so have no reason to put it in Tow Haul unless I want it quicker off the line and with the Pedal Commander it’s pretty damn quick. Hoping someone will come out with a programmer soon so that I can adjust the top end limiter.
    Sdid
    Sdid
  • Who's Online   7 Members, 0 Anonymous, 1,489 Guests (See full list)
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
