If anyone is interested I have a brand new suspension maxx leveling kit which comes with 2.5 in the front and 1.5 in the back. I have the full kit and it is for the 2019 gmc 1500 denali. Looks like a great kit but I do not think I can lift my truck and still fit in my garage so im just going to leave it stock. If anyone is interested let me know.
  • 3 weeks later...
For you guys who have done this, do you have to re-aim the headlights or reset any of the steering sensors etc? Thanks in advance!
The only adjustment I made was the headlights. The cameras are slightly different when parking, but I think that is a good thing because it keeps me further away from objects.
Need to go out and measure my truck, but after reading it looks like some guys are saying the Rough Country 2" kit puts the nose high and 1.5" is perfect to make it level. Can anyone confirm? Thanks in advance!
Anyone have any first hand experience with the suspensionmaxx 2.5 front and 1.5 rear level kit with ARC bracket?  Any concerns with front end wear issues?
looking to get the rake out of my 2019, this looks like the best option that I’ve seen
  • 3 weeks later...
On 2/3/2019 at 1:56 AM, Jeff Rago said:
The difference between the Denali and Chevrolet suspension is the ARC component.  2019 Denali requires an extension of the rod which is approximately 3/4 of an inch for a front level kit.  Rough country has them now and you can see them online.  You will have to do the same to the rear (extension) should you want to lift it also.  Other option is to replace the shocks.  These are not electronic “magnaride” but fully mechanical and controlled by the rod based on suspension travel.  You can measure the rod in stock state and then with the lift added.  The difference is the additional length you will need to make a bracket for,  to add to the rod length.  I did this on mine and just ordered the Chevrolet leveling kit.  The GMC was almost twice the price for the two, approximately 3/4 inch extensions, two lock nuts and two bolts.
Do you happen to have a picture of the ARC bracket? Also the dimensions from hole to hole? I have a left over kit (non ARC) and also rear blocks I am going to utilize.
No dimensions though, just pulled this off the internet. I’m going to do my leveling kit this weekend.
  • 1 year later...
    • Welcome back! No, it definitely doesn't pass the sniff test. Even "ceasefire" needs an alternative definition these days.    $5.29 at Kroger today
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • 2024 Silverado 2500 HD LTZ grille no camera Parts list   84603331 84913656 84913657 84913654 84913655 84911567 84911568 85646092 85646093 85797921 85797922   11570637  x10-15   grille/bumper bolts 11546500  x10      grille clips 11571006  x10      push/retainer clips 11546454  x6       nut retainers 11611609  x6       M5 bolts 11610700  x6       molding/trim retainers
    • And use RA's 5% discount code if you buy from them.  google for the code, one is always available.
    • Just don't turn the steering wheel as much?
