If they even let you actually turn the system off when it freaks out that would be a huge help. The switch to disable the lane keeping system has no effect on the constant stream of flashing alerts on all the screens...
I might have to try putting some sort of trailer light plug with heavy resistors in it so the truck can pretend there is a trailer back there and shut the heck up about this garbage so I can actually drive the truck safely.
It’s bad enough that NHTSA should be engaged about this type of driver distracting behavior and strongly encourage automakers to take action.
Edited by flowbytwo
Spelling
If i could do away with options for my truck these parking sensors would be at the top of the list. They are without a doubt more of a nuisance than a help it seems, especially if your like me and live in a snowy climate as they always trigger a false detection with ice or snow buildup around the sensors. Sorry guys who are new to these trucks but i don't see software updates fixing this issue, been pretty common for the last 5+ years anyways. Mine just eventually thankfully shut down all together when they start freaking out hopefully they kept that feature.
I had random errors with my sensors on my '17, but as you said, when ice or snow was built up. I have the same issues with my 2017 Accord Touring, so it's not just the GM trucks that are affected.
This seems to be to do with the trailer connection specifically.
Sent from my SM-N960W using Tapatalk
I’m going to try to unplug the trailer connection and slather it with dialectic grease
Then reconnect I’ll let you know what happens supposed to be very cold this weekend
Ive already tried this and nothing change its all about the programming in the computer or the trailer module the dealer is with GMC on this they are waiting for an update we only can wait for it !
Envoyé de mon iPhone en utilisant Tapatalk
I am having the same issue.  Seems to have gone away again, but I am assuming it is only because it has been slightly warmer.   This is definitely an issue GM should be working on.  It is different than simply the terrible parking sensors beeping when moisture is present, which is an entirely different complaint.
Edited by CarlsonDDS
Thanks I put the grease in the connection under the bumper
When I unplugged quite a bit of water came out
I greased both sides of the plug
I’ll have to make sure I follow up with my dealer also
I’ll let you know if I hear anything
Had mine at the dealership Monday they reflashed and the error was there when I stopped at the light 2 blocks away [emoji2959][emoji1745]‍[emoji3603][emoji1745]‍[emoji3603]
Mine was at the dealer yesterday but it decided not to throw the errors when the tech tried it.
According to the engine hours on start up they only ran it for 0.1hrs so they must not l have tried very hard to see if it would fault.
I suspect it was simply plugged in to read codes and there weren’t any in the computer.
You were right
The grease didn’t change a thing
I’m experiencing the same issue here in Iowa was 1degree out side last night and got all the flashing errors.  This isn’t acceptable for a 50k truck.  GM/Chevy fix it or you’ll have a lemon law on your hands.
I also wanted to mention the windshield wipers are horrible what happened to the OEM beam style
I ordered some Bosch
My front sensors will normally go off after power washing the vehicle with it being cold out. I would just take a heat gun to the four sensors and my sensors would be okay. After washing the salt off with it very cold, the front and back acted up. So I dried the trailer connections out and all of my sensors worked correctly under the same weather conditions. So who knows....
Edited by Rocz3cqg
Add me to the list. 12 degrees this morning. Trailer disconnected, lane change alert and then rear cross traffic alert messages about a dozen times in 5 miles. The infotainment screen flashes every time this happens. It’s all very annoying. Not even going to bother taking it to the dealer until there’s a TSB and a fix for it. Hopefully we can keep each other posted.
Taking it to the dealer
tomorrow told them I wanted it fixed or they can have the truck back this is a driving hazard, distraction not to mention not make not trust the systems on this vehicle. Again I don’t pay good money for this crap.
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
