I hear you. Let me know what they say. I hate to lose work time and have mine back at the dealer less than a week after I bought it but it’s getting to that point. After I posted, it must have did it another 20 times when I went to lunch and I’m just annoyed as can be. I messaged the dealer to see if they have any inside knowledge on the problem. I’d be more encouraged to take it in if everyone on this thread who brought there’s in didn’t continue to have the issue.
Add me to the list of those with these errors codes.  Extreme cold is causing it.  I am in MD and this is the first time it has been below 15 degrees since I bought the vehicle.
This is my second time in to dealership for it first time I think they just checked for error codes etc and said they reset some things but didn’t find anything glaring.  I’ll keep you posted what they say tomorrow.  Also just ran out to do some errands and it’s 15 out it did the errors for first 5-10 minutes in the car then stopped for a bit but then came back again.  Pretty inconsistent and the truck is clean so no sensor imparement.
I'll be taking mine in for the second time at the end of the week. They did the same with mine the first time, and they found no errors.
We will see how it goes this time.
Let's all keep posting in here with updates if we can. Any info helps that we can pass along to each other.
Thanks
Sent from my SM-N960W using Tapatalk
Just got a call from the service advisor. He said the GM engineers are still trying to figure out if this is a hardware issue, software issue or both. He said it could be weeks to months before a solution is identified but that it is a known issue and they are working on it.
I filled out an online safety complaint with the NHTSA after the distraction almost caused me to read end someone. I hope if others do the same GM won’t be able to just ignore this thing for a few months.
On the clean/dirty sensor thing...
Today I drove over Teton pass... heavy wet snow. Incredibly bad conditions. Some of the worst I have driven through in a couple years.
The truck was fantastic, the tranny did exactly the same ‘holding gears and soft up shifting’ to hold downhill speed as I would have done with a manual. I haven’t had a trans that doesn’t slam gears with a manual up shift when the rpms are high during grade holding before this one. Truly impressive.
Front wheel drive cars in the uphill lane headed towards Jackson couldn’t even get up the grade due to ice. (I hope they like their ticket for ignoring the 4x4/chains conditions in effect signs). The trucks was totally composed through it all mostly around 20-30mph.
Anyways, back on topic. After 200 miles in heavy freezing slush my truck was encased in tons of ice. The running boards were full to the bottom of the doors (might be a design issue there— at least something to watch for). The sensors front and rear had at least a half inch of ice. Putting the truck in gear made it pretty unhappy for a bit with the buzzing seat until I got moving.
All that time though the trailer thing did not go off. To me this means the issue is strictly the trailer connection system and not the parking sensors. The alerts about disabled parking sensors and rear traffic are probably just what it does when it thinks there is a trailer connected.
Yup, I think you’re right on the money and I will also fill out a complaint. I’ve noticed similar things...I had my truck out in a blizzard a few days ago, parking sensors covered in snow and ice, did not have the issue. Today the truck was pretty clean, but it was much colder, and the error was happening non stop. I wiped the sensors off and it still persisted until it got above 20 degrees outside. Almost everyone on here talks about the issue at below 20 degrees. There is something to it, and it’s temperature related, not snow or dirt on sensors.
I am thinking the same.
That being said, I've had lane keep assist and lane change alerts cycle on and off as well. Both would not be affected by a trailer being hooked up.
So the stuff at the back of the truck, I do think you are correct.
“LCA is disabled when the trailer connection status is displayed. A DIC message may display. The SBZA system still operates.”
I’ve haven’t had the lane keep assist fail yet, but the LCA and the trailering features are definitely connected, and I think the trailer problem is taking out the LCA and causing the two errors, one after another.
Same issue here. Less than 600 miles on 2019 1500. It's at the dealer for the second time in less than three weeks (2 of those weeks it wasn't driven). Took it out in the snow five blocks to grab a bite and on the way back home constant trailer disconnected messages on the dash. Dealer told me today it was water/moisture in the sensor again and I would just have to deal with it until GM has a fix. Calmly told them that was unacceptable and I would pick the truck up when it was resolved or they can take it back.
What was their response?  Seriously I was on the verge of getting my 3rd tundra but really liked what the Chevy brought to the table now I’m 2nd guessing self.  I really
like the truck but man this is just bad for a brand new model. And to say it’s moisture and temps is so typical dealership bs all they care about is selling the car.  They need to be our advocate here and get it fixed and communicate it to the owners.
They contacted GM and are waiting for them to respond. Hopefull will have an update tomorrow sometime. After reading these posts I am not real optimistic
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
