Ideas to increase half ton fuel range
I would think if the auxiliary tank was sealed it wouldn't affect anything. What about vehicles with stock dual tanks?
It was awhile ago on a diesel. I tapped into the return line to the fuel tank, I used an old fashioned switch like on old trucks. I had a toolbox fuel tank setup. When the truck tank ran low I would manually switch on the gravity feed to the return line,fill tank switch off.
Diesels have no vapor emissions like the gas vehicles and have a sensor in the tank so that trick wont work on 1996 and later trucks.
The PCM is programmed for RPO NJ9 for dual tanks and a different parameters for increased capacity on the vapor test.
I can count on one hand in thirty plus years the times I've turned my motor off to refuel.
The computer would detect a refueling event and not set a code when the transfer tank dumps fuel into the main tank.
Wavian Jerry Cans are the best, blue and red cans in the photos above.  Get the real pour spout, not the government one too.  They're awesome.
I never shut my diesel trucks off.
This is my first Chevy gasser...will it throw a code if you refuel with the engine on?
I’d rather leave it running with the climate control on...
I often leave my rig running when I'm refueling. That way the wife can have the heater on, and she can continue to watch Frasier / Seinfeld on the in dash DVD system while i'm out filling up the tank, cleaning the windows, checking the trans fluid, etc.
My only concern about externally mounted fuel cans, is the fact that fuel is flammable. If your rig rolls over, there is going to be one hell of a fireball to deal with. Like these guys that have them mounted on the front or rear bumper - what if you hit someone, or you get rear ended?
Here is a fine example:
https://www.liveleak.com/view?t=aihFh_1543069533
Another option is the "Rescue" fuel. It is extremely safe, when compare to regular gasoline.
Although it will burn under the right circumstances, it will not explode or create a "flash" fire. It wont even ignite in an engine, unless the engine is hot. If you try to start a cold engine with this stuff, it simply wont run. You have to add it to your fuel tank soon after it runs out of gas, and then make sure to get more gasoline before letting the engine cool.
Its a great product to have on hand.
Might not be what your looking for if your trying to extend your range by hundreds of miles, but it sure is nice to have when your looking at the "Fuel Low" indicator on the dash. Will I make it to the next gas station?
This is my first Chevy gasser...will it throw a code if you refuel with the engine off?
It should not.  Once started, the computer is going to check the fuel level against the time before it was shut off, or something along those lines.
Tank pressure code is only set of the computer senses multiple fails over a period of time. So, you can likely fill tank with engine on. . .
. . . But, cleaning up body parts from all over the station is annoying for the station attendant to clean up [emoji6]
Nonsense.
    • I'm suborn like that Ed. There's a plaque in my doctor office that says, "Don't quit, take a break." Works for allot of things.    Reality is, the wife loves her SUV and even given it's issues, she'd buy another if she found one with low enough miles. Then again she has me to maintain it.    Most of what ails this thing is GM shooting themselves in the foot and by extension the buyer. Besides a ridiculous breather system the cat warm up strategy, IMHO, is the dumbest thing I've ever seen an OEM do to a vehicle they warranty. On cold start it r-e-t-a-r-d-s the ignition to like -17* ATDC and dump fuel like kicking over a pail to force combustion in the CAT's for rapid warm up. This literally hoses the oil off cylinder walls and creates enough varnish precursors to stick rings in even well maintained engines. THEN if that wasn't bad enough they recommend using a wanting fluid specification at equally stupid interval.    Common to all GDI motors I'm aware of is this silly practice of driving the HPFP off the cam giving a leaking pump direct and unchecked access to the crankcase. And sir, eventually the ALL leak. Your job is to "catch it if you can". Yes, these are the same people that removed dipsticks from engines and transmissions in belief Joe Average wasn't capable of checking, reading and maintain his own vehicles fluids. Sadly  and in large they were correct. Most people these days can't tell a sparkplug from a fire plug.  Great ideas one and all.    Every move and every error calculated to defend themselves from the law and their own customers.
    • Most online suppliers and Amazon. All have noted "not for use with Bose speakers".
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
