2018 sierra 1500 curb hit
Sharp780
Hey all so my stupid self driving through parking lot at the mall less than 2000 miles on the truck doing about 15 mph hit a curb up and over it. In my defense it just snowed 7 inches couldn't see the thing. Should I be worried about anything being wrecked? First new vehicle so pretty paranoid now.
Sent from my SM-G930W8 using Tapatalk
If it still drives straight and there isnt any vibration at highway speed id say you are ok, the worst u may have done at that speed is scuff a rim
Ya I didn't scuff the rim so that's good I hit it dead on though the curb it was one of those curbs that they put up to separate parking between stores like a foot wide by 4-5 inches high. So that's kinda what's making me worry abit.
I did take it on the hiway though after and it didn't wonder or anything it seemed.
Dont worry then, the parts that could of been damaged by a harder impact like that would of been evident driving down the road after the impact, ie bent rim, bent tie rod, bent sway bar just to name a few but like i said the damage that would of been possible would of shown up immefiately by a shake or vibration while driving, but even if you had a shake or vibration after that it could be something as simple as snow packed on the inside of the rim but i belive you are ok
Alignment issues and/or bent knuckle would be the main things I’d worry about.
Easily checked - is the steering wheel straight when the truck is driving straight?
Is your tire wear normal or not?
In all likelihood it’s fine.
Pronstar, he just did it so he wouldnt notice tire wear , but i said basically same thing as long as its driving straight and not vibrating or shaking, i didnt list evey part that could be damaged just a few, but i didnt know if you knew that he JUST did it , thats why i said about not showing tire wear, plz dont take this as a attack i was just wondering if you knew it JUST happened thats all, obviously the more eyes on the situation the better for all us :)
Thanks gonna actually get it on the hiway today make sure it's not shaking or nothing at speed.
That's a lot of snow.  What part of the country?
Jim
Manitoba Canada.
Central Alberta it's been snowing pretty hard for the last 2 days
I had a curb jump out in front of me once,   seriously though, I would take it in for a evaluation, just in case. Have them put it on a lift and do a thorough inspection. It's new,  so check it out.
Ya I'm thinking I'm gonna pop into the local dealer have them check it out just for peace of mind gonna get it on the hiway this morning see if it shakes at all at hiway speeds but ultimately would still like someone to look it over.
It's unlikely there is anything wrong at all.  But, if you're worried, don't hesitate to have the alignment inspected, which will reveal if any of the adjustments have shifted, or something got slightly bent.
Your very welcome, also get on a straight stretch of road and carefully let go of the wheel ,it should stay moving pretty straight for a while (pending the road is smooth and not pitched heavy one way or the other)
At first it seemed like the balance was off but we got a pile of snow here so went and washed everything out and seems good I booked it in for a once over tomorrow just for peace of mind.
glad to hear it,
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
