My 2016 WT had better rear camera clarity then my 2017 SLE.... Still works, just looks like your'e looking through water.
My 2014 Sierra Camera sucked, the 2016 Sierra it was great, The new 2018 Silverado it's blurry again :(
Is this just a quality control issue with the Camera's?
I didn't realize how bad mine was until I test drove a 19, the clarity made mine look like a POS. I will say that the one on my 18 is better than the one in my old 15, so for me at least, they're getting progressively better.
We are talking about the back up camera, correct?  I didn't thing GM offered a rear view camera until these 2019's came out.
The back up camera on our Suburban is ok, but really sucks at night.
I could read a newspaper headline with my 2014 1500 Sierra camera (im exagerrating but it was very clear).  Just bought a new '18 2500 6.0 SLT and the rear view camera stinks!   Value engineering strikes again.....
Anyone figure this out yet? I just bought a 2017 suburban premier thinking it was top notch, but the camera was garbage. My 2019 Ram looks 100x better.
I've had the same camera experience as others.  Had a 2014 1500  with a great camera.  I drove a 2019 old style 1500 for 2 weeks that had a great camera.  Bought my  2015 3500 and the camera was terrible.  So I took a gamble and bought GM# 84079952.  This is the replacement for a 2019 HD with 8' box and with out remote tailgate.  The picture is fantastic.  Only trouble was I had to swap the old connector (6 pin) onto the new camera (8 pin).  The extra 2 pins are for the power locking tailgate.
U mind posting pin outs, which is 12v+, 12v-, reverse signal, camera +, camera -. There are 2 grounds that are joined together.
has anyone figured out how to access the rear view camera  without putting it in reverse? when i'm towing my log splitter it would be handy to be able see that it's ok back there. i've got a 2019 2500hd.
84062896 camera VS 84079952?
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
