My Air Lift SlamAir helper bag kit arrived and I'm wondering where you guys and gals mount the inflation valve. I'm going to "T" the lines together and have a single inflation valve. I don't see a situation where I'll need to load level from left to right.
Thanks in advance
Tom
Why not just do an on-board air setup so you don't have to even mess with that BS?
I like the license plate bolt idea, that's slick. I don't want to mess with an onboard compressor. The only time I'll need to add air is when I tow the trailer and I have a Milwaukee 12 volt inflator on board at all times. e7eb0270261fcf0a453e06130fb40c25.jpg
Agreed it’s really overkill unless you’re using it every day. I tow once a month and thought about getting the wireless one system but 350 bucks is a decent amt of coin for something that will barely get used. I’ve read a few reviews stating the manifold leaks at time too.
Exactly, sometimes less is more....
Yep.
The license plate bolts are easy just pop the plastic piece out.
I used the second valve on the other side so it looks the same. Actually had them plumbed separately at first but they didn’t get along with each other (one side would be half an inch to an inch lower at the same pressures. Airlift suggested for towing just plumb them together. Equal load.
Had the FireStone AirBags on my DMax with remote in cab switches. I loved it when towing my 5th Wheel and especially during rainy days it was very convenient not ever having to get out, standing outside in bad weather manually filling air bags that literally needed resetting air pressure. Very convenient but not if you’re towing once or twice a year.
Sent from above
Agreed. I tow my boat 1-2 times a week.  I would hate to need to fill/empty the bags manually each time I towed...or worse yet, each time I go down the boat ramp.
Smart Air 2 setup is $350 but you don't even need a controller. Just does everything for you and basically replicates what GM used to offer with the auto-leveling suspension (which I really miss having).
I’ll look into the firestone one. The wirelessOne from airlift seems pricey and has iffy reviews
4 hours ago, djw88 said:
inside the gas door
Exactly where I put mine to. I have installed 2 Firestone kits on a 2007 1500 and 2011 1500 never touched them since. Work great.
Edited by crankman
I’d stay clear from the wireless setup, fixed dual gauges under steering wheel is what I had and worked great. Just make sure to get the dual gauges that are lit up.
Sent from above
    • You could try a used 1, they used that engine in the Astro vans, Plenty of them in the boneyard. Look for a wrecked or rotted 1 so the chance that it was scrapped for that reason and not a mechanical issue will be greater
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • That computer lies!
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
