On 11/8/2019 at 3:13 AM, code-man26 said:
MotoFab 3" front leveling kit (even though it's a little nose high) (going to add Deaver leaf springs mini-pack in the rear for a 2" lift when it's released)
17" Method Double Standard wheels (had to use 1/2" spacer to clear the caliper)
Toyo Open Country R/T 285/70/17
Is the backspace of Method wheels or is it the 17 inches wheels in general that you needed a spacer?
Edited by im33303
24" honeycomb replicas  silver/machined.  +31mm offset.  1/4" spacers in the front to clear calipers.  35x12.50/24 MTs.  Leveled 2"  Barely any rub only in reverse.  No trimming.
On 11/7/2019 at 3:21 PM, 808 HI said:
24x10 +31 Escalade reps on 295/40 Atturo tires
Great looking truck!!!
Perfect stance!!!
That is an awesome looking truck, looks like a "big hot wheel"!!!
Could be a dumb question, is that special order/program factory color, or a wrap on the bottom 2/3 of the truck?
its a vinyl wrap.  I left the top as is!
Looks great, what color is that?
Nice touch with the American flag on the slider too!!!
And welcome to the site.
Edited by JimCost2014
Thanks!!  It is 3M Satin Ocean Shimmer.
I make and sell the flags! I have them for the 2014-2018 and the 2019 up!
What was the cost on the wrap?
i did it myself...  materials cost about $1k.  A shop would charge probably 2-4k depending on how in depth you went with it..
Thanks for the quick reply....Nice looking truck!!
The "spokes" as I will refer to them, contacted the side of the caliper. I know 4.75" backspacing (which is what these have) clears on other wheels but apparently not the Method Double Standard wheel. Breaks my heart having to use a spacer but, eh, it's only 1/2".
On 11/7/2019 at 9:08 PM, NCD said:
Wheel and tire size? Offset? Trimming required? I have 3 practically brand new 20x10 -12s with 305/55/20r that I’m trying to figure out if they will rub before I replace the 4th.
