Steering bind
2003 Sierra HD 2500      Hydro boost.     I am finding that the steering has spots that it feels stiff as the wheel is turned.  it is more apparent turning left.  Not so much right.  On warmer days it is less pronounced than on on cold days.   That can very as the temp rises through the day.    As the wheel turns it gets stiff in spots and loosens up through other parts of the turn.  Drives straight fine. No greater than normal correction needed.   Still turns ok.   No noises or thumping sensations in the wheel. No drip marks on the ground.  I will get a closer look from the under side once the snow melt allows me to get on the ground.  No visible leaks from above.  Just the steering hoses that do need replacing.
  Bearing Problem? seal issue? Fluid Problem?  If so is it something in the bearing hub that needs checking or filled?
Thank you.   I do expect questions
Shane
Update:  If i release the wheel in a turn, it does not self correct back to straight.  I dont have to fight the wheel either
Update #2   I got under neith er and was able to look up.  The point where the steering wheel shaft enters the hub, a cap piece has popped off and is dripping. not actively dripping when parked.      Now when i let go of the wheel, it immediately steers right and continues to turn.  even when I turn left and let go, it immediately reverses right.   But I am still not having to fight it when going straight.
Greasable replacements?and lubed periodically?and taking grease?one way to isolate is,pop a tie rod end off,then you could turn each side individually,or steering box is starting to fail?
Or disconnect the pitman arm from the center link, with the front wheels off the ground, and see how it feels moving the wheels left and right by hand?  You should be able to feel any stiff spots that are bad enough to feel when driving.
riverbanks, davester   I will take a look at those.  I was able to get underneither today and look up.   A new update has been added with new details
Did you mean "power steering gear box" by "the hub"?  If so, sounds like you need another one...
Yes.  I have seen it listed under a couple of different names.
