I can not find anything that tells what size the dash speaker is.. According to Crutchfield it's a 2.75, My question is will a 3.5 fit?
Also It says The Front doors will take a 6x9 is that with an Adapter?
Could it.... without cutting.....NO.  But I made em fit..
How difficult was cutting that open enough to fit.
Sent from my LG-G710 using Tapatalk
It was really easy with a Dremel. Bit then i made a frame for the Focal because there was about 90% of the factory mount that was moved.  You cant just trim around to make them fit.
Awesome. Thanks!
So were you able to get in down into the dash where it is seated? I'm Thinking about going with some Kicker Coaxial that are 3.5 and doing the Kicker 6x9 and the Kicker rear door also.
Yup. It took some work and not being afraid to cut. The only thing you see is the tweets on top of the grills. But I might change the mounting for them too.
How do you like the tweeter placement? I put mine (Focal too) in the door sails with the same Mounts pointing at me. I think they are too close to my ear and therfore maybe too bright. Was considering a flat mount in the same location to see if that helps, or up on dash like yours.
My tweets are facing more towards the side of the truck. I also have the jl 800/8 vxi amp so each of the 8 are individually tuned to frequency, gain, time allignment. I didnt want to to put the midrange in the door next to woofer because I wanted to hear more mids higher up front facing me. So the doors have the woofers, and the dash has the mid and tweets. Pretty much how it was with the factory Bose i ripped out. But the Bose top dash speaker is almost a full range crossed over at 400.
Edited by RACERX7775
How does the factory non Bose head unit work if you just buy better speakers? Will it sound much better then stock or not worth changing out OEM speakers?
9 hours ago, RACERX7775 said:
My tweets are facing more towards the side of the truck. I also have the jl 800/8 vxi amp so each of the 8 are individually tuned to frequency, gain, time allignment. I didnt want to to put the midrange in the door next to woofer because I wanted to hear more mids higher up front facing me. So the doors have the woofers, and the dash has the mid and tweets. Pretty much how it was with the factory Bose i ripped out. But the top dash is almost a full range crossed over at 400.
Does your setup still have factory headunit? If so, do you notice if the dash speakers still produce significant volume even when the headunit is faded all the way to the rear? I am trying to sort out if I got something hooked up reversed, or if that's just the head unit’s steering for environmental sounds reasons. I have a Nav-TV and JL HD amps. Doors and sub on one amp (4+1), dash on the other (2). I kind of wished I had looked into the Vxi amp series, for the extra control.
20180721_194326.thumb.jpg.3e2a134430496d70622c13946cddd64c.jpgYeah, i have the nav-tv piece too. $850ish.... I do have the factory head unit. There should be zero sound when you fade any position.  But I have the 800/8 and the 600/1 vxi amps with the jl hub. I ran a single optical wire from the nav-tv unit to the vxi hub. Then optical from the hub to each amp. So that way, there is no RCA cables in the truck. Then from the amps to the speaker wires at the bose amp harness. I ran extra wires up to the dash for the tweets. I also have the jl bass control knob. It has 3 controls that you can make it do.  At full left, it has fade to the front. At full right, it has fade to the rear. Then the knob is for bass control. Then the front button i tap to run to different system crossover configurations.  So its all tuned via my laptop. There are NO knobs or settings on the amps themselves. So i have every input setup to exactly what i want.
Add more content.
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
