The "Catch Can" Explained - By Elite Engineering
  • Replies 698
This is sickening,
Hard times here can't afford a catch can... Layed off looking for work and my wife is having serious medical issues.... BUT I love my new truck... 2016 1500 5.3 LTZ I planned and dreamed for years. Now thinking this sludge is building up and damaging my engine makes me cringe! 50k for a truck and I (We) have to even think about this as a MUST HAVE is criminal.... I'd like to grab someone from GM by the nutz... If it can be proved this is happening to our engines why on earth has no one Sued? In my thinking this is a HUGE deal...
I'm sorry but this just FLAT SUCKS...
Keith
If you can't afford a catch can at this time. The only other alternative to cleaning your engine from all the negative effects of direct injection is to do or have a shop do a direct injection service. Or take your intake off yourself and manually clean your valves. But there will still be junk on your pistons
If'n you don't mind trik396; what brand "catch can" are you using??
Just axing of course.
Joe I have an elite
I think I've talked myself into ordering a catch can. I bought the truck new (2015 Sierra), currently sitting right at 40.5k miles. I'm not mechanically inclined, is there anything I should do prior to install? I'm sure there's plenty of junk built up over the last 40k. Should I initially check the can more frequently?
Sent from my kayak
Sent from my kayak
The install is super easy on these trucks, and we have several installation videos on our website. The first time you install the Catch Can, check it after 1K miles (especially in cold weather), then again at 2.5K miles. Once you have a little history, you'll get a better idea how often it needs to be emptied.
Thanks for the reply. Every thousand miles means I have at least 40 check can/empty can sessions I have missed haha. I think I can handle the install, I wasn't super clear, I was more or less wondering if I should have anything on the engine flushed or something of that nature before installing?
Have you ever had an induction service mcskeet?
I sure haven't. I have a history of not staying in vehicles for very long. This was my first new vehicle purchase, and I intend to keep it as long as I can. I'll get my Google on and check it out. Thanks.
Sent from my kayak
  • 3 weeks later...
Which can should i get for a '16 5.3? Truck has 8000 miles on it and I've saved up for this truck and i want to make it last.
Our E2-X and E2 Catch Cans are the best performing Catch Cans for your vehicle. We offer these in both Single and Dual Exit Port and have a kit specifically designed for your truck.
Here are links to them both:
The E2 Part number for this vehicle is:
Listed here: http://www.eliteengineeringusa.com/e2-catch-can/
The E2-X Part number for this vehicle is:
Listed here: http://www.eliteengineeringusa.com/e2-x-catch-cans/
The E2-X "Kit" comes with check valves, and all hardware you'll need. You can order it with or without the Clean Side Separator. The "Kit" comes with the Clean Side Separator too.
The E2 Catch Can Kit, you can add the check valve or Clean Side Separator.
Let us know if you have any questions.
We can always be reached at:
[email protected]
Get the bigger one and go 5,000 miles before dumping! It probably will handle the 7,500 Oil Change interval no problem though.....
That would be our E2-X "Ultra" Catch Can, it's a beast and because of it's larger size, you can go longer between emptying.
