The "Catch Can" Explained - By Elite Engineering
With all the talk about Catch Cans, we thought it would be a good idea to combine the information into a smaller thread here.
To better understand the purpose of a good quality PCV Oil Catch Can and why they are important, we need to first understand the purpose of your Stock PCV System:
The PCV (Positive Crankcase Ventilation) system on your engine is designed to regulate and remove fumes from the engine crankcase, and to alleviate crankcase pressure which could cause oil leaks or seal damage. It’s a way for gases to escape in a controlled manner from the crankcase of an internal combustion engine.
During normal operation of an internal combustion engine, there’s a compressed air and fuel mixture inside the combustion chamber that is ignited and as a result, forces the piston down. A small amount of that ignited mixture leaks past the piston rings and ends up in the crankcase.
This leakage is often referred to as “blow-by” (leakage past the piston rings), as well as oil mist. Some of the oil mist and other products settle along the engine intake and over time form a “gunk.” The oil catch can collects the oil mist and condenses the fuel vapors while allowing “cleaner” gases to be passed back into the intake.
If these contaminates are kept inside the combustion chamber, they will eventually make their way into the oil inside the crankcase and cause oil contamination and dilution or make their way back into the intake manifold.
This problem has been documented in many automotive magazines, Car & Driver had an article covering this topic (Carbon Deposits with Direct Injection) There are hundreds of images on the Internet of Carbon Build up on Intake Valves:
http://www.gm-trucks.com/forums/topic/154204-oil-catch-can/?p=1608015
The purpose of a proper oil separating Catch Can is to route these gasses through a baffle system that provides the most contact possible with the outer surface resulting in the oil being trapped and removed from the other gasses that do continue on through the intake and are burnt and consumed. Typically the trapped oil is captured in the bottom of the Catch Can.
If you do your homework, you’ll find a lot of good Catch Cans on the market. You will also find a lot of products that claim to be Catch Cans but have no internal design or baffling to create the optimum amount of pressure drop to pull the oil out of the vapor.
Many Catch Cans on the market are just comprised of an empty container with 2 ports. While that simple design may trap a few oil droplets, a well-engineered Catch Can is designed to condense the oil vapor and trap the oil inside the container.
As I said, there are a lot on the market, go with a company you can trust.
  • Replies 698
This is my third Elite catch can. They flat out work with no issues. Great company to deal with and excellent customer service. Attached is a picture of my catch can after only two hundred miles. The truck had 1500 miles when the can was installed.
So please prove to me before and after pics of a catch can keeping valves clean...
What happens when that catch can fills all the way up?
You have to empty it periodically before it fills all the way up.
The difference between a "catch can" and an "air/oil separator system", as used on a number of OEM vehicle applications, is the drain back to the sump.
If GM had put a catch can on a vehicle, we'd hear cries of being tossed back into the 20s, when you had to grease the rocker arms before running your engine. A catch can is fine for the race cars and street rods, and even the meticulous street gear head. It's not something you want to forget to service.
I chose to buy a separator type with a drain back to the sump. This is an OEM type product that needs no routine intervention to drain. In addition, it has protection from overpressure with a bypass valve as well as a crankcase pressure regulating valve for supercharged engines. These types of systems are used on numerous OEM installations, including BMWs to large turbo-supercharged diesel truck applications. http://www.grupoherres.com/v3/intro/boletin/mann.pdf
https://www.mann-hummel.com/en/corp/products/crankcase-ventilation/
If you believe all the stuff we're seeing is oil in these pictures posted on this forum, their oil pans would be empty before the OLM change period. The fact is that much of what we're seeing in these pictures is a large quantity of water condensate mixed with oil.
You should research the various products out there and chose for your application, situation, and as importantly, your lifestyle. My lifestyle is to expect to use the truck like GM intended, with a similar maintenance schedule. That doesn't include remembering to drain a catch can. YMMV.
Spurshot - would you be willing to post a couple of pics of how you installed your separator? I've been piddling around with the idea and like the price point and what I'm seeing from Mann-Hummel. Any issues with installation or function? Thanks
Look on the bottom of these installation instructions, this is how we connect the Clean-Side Separator.
http://www.eliteengineeringusa.com/content/Catch_Can_Install_Chevy_GMC_2014_5.3L_6.2L_Truck.pdf
I've already installed the Elite Catch Can and am happy with the results so far. How important would it be to add the clean side separator in addition to the can? How much oil gets by with just the can?
OK, so I'm going to ask the obvious (and maybe stupid) question...
If this is an issue, why aren't catch cans and/or oil/water separators installed from the factory on every vehicle?
If the manufacturer can clear the powertrain warranty without issue, why bother (from the manufacturer perspective)? These are just to hopefully help us owners who want to extend the life of the engine and keep it as close to a new engine as possible
Virtually all vehicles have some type of air-oil separator in the PCV system. Most are simple baffle/labyrinth style. Some are very sophisticated. Nearly all will have a drain back to the sump.
I recall a round breather cap style with a hose bib on an early 60's car my father owned. It had baffles and drained back into the rocker cover like the RT and Elite "clean side" caps, but it went to the PCV valve.
PARTS-MASTER-14075-Crankcase-Breather-Ca
The foreign cars seem to have more sophisticated centrifugal or filter type separators. The American engines seem to have the least efficient/effort designs.
  • 3 weeks later...
Still not seen evidence this actually keeps di intake valves clean like they all advertise.
    • Replace the fuel pump with an OEM AC-Delco.
    • Hello, first time posting here. I have an 03 Chevy 1500HD with the 6 liter gas engine. The truck ran fine until the fuel pump died on me and had to get it towed. Replaced the fuel pump with a precision pump from O’rileys and changed the fuel filter while I was there. The truck will run and drive now but it wants to idle around 500 rpm when in drive and it tries to stall if you touch the gas. It drives fine though, just doesn’t want to idle. Put a fuel pressure gauge on the rail and only have 50 psi. I guess these trucks should have 55-62 psi to run right. I thought the regulator might be the issue because when I would unplug the vacuum hose it jumped to 56 psi. Replaced the regulator and no change. The only thing I can think of is that I was sold a faulty fuel pump. Any help would be appreciated because I’d rather not have to take the bed off again if I don’t have too. Thank you!
    • I've been wrenching on GM trucks for 17 years. And I need to get something off my chest because it's been weighing on me for a long time. After all that time, all those motors, all those people standing in my bay, I've figured out there are really only two kinds of owners. The ones who already know about this. And the ones who are about to find out the hard way. A guy came into my shop a few weeks back in a 2018 Silverado 5.3. Sharp guy, maybe 35. Knew his truck cold. He'd been on the forums, read the threads, done his homework. He only rolled in so I could double-check a little module he'd already plugged in himself. Wanted a second set of eyes on it. Ten minutes, in and out, drove off happy. Two days later, a completely different story walked through the same door. Older fella this time, in a 2016 Sierra. Gorgeous truck, clearly babied, not a scratch on it. Wedding ring. Looked like a guy who took care of his stuff. He was in because his engine had started knocking on the way to work. And by the time I got the valve cover off, I already knew it was too late. Lifter collapsed. Cylinder 5. Camshaft chewed up. The whole top end shot. Same kind of truck. Same motor. Same roads, probably the same dealer. The only thing separating those two men was information. I've been at this since 2008, and I've worked on everything GM puts out. Silverados. Sierras. Tahoes. Yukons. Suburbans. Escalades. The 5.3 and the 6.2. Doesn't matter which badge is on the tailgate. They all carry the same problem. So here's the information one of those guys had and the other one didn't. It's called Active Fuel Management. AFM. GM started building it into their V6s and V8s back in 2007 to squeeze out a little better mileage on the highway. Maybe a mile or two a gallon. All to hit government fuel economy numbers. The way it works, the motor quietly shuts down half its cylinders when you're just cruising along. And the little lifters that pull that off have a tiny pin inside them that's constantly clicking in and out. Lock, unlock, lock, unlock. Hundreds of times a drive. Thousands of times a week. Eventually one of those pins wears through. The lifter drops. And it starts grinding the camshaft down like a chisel on butter. And what nobody tells you is that the shudder you feel around 40 or 50 mph? That's the system cycling. Every single time. Here's what really gets me. The pre-2007 trucks, the ones without AFM, they're bulletproof. I've got customers still daily driving them with 260,000 miles on the odometer. Not a problem in the world. GM took a perfectly good motor that would have lasted a lifetime and bolted this system onto it. And it is wrecking engines that should have run forever. The guys who hang around the forums already know all of this. So do the techs. They handled this years ago. They didn't sit around waiting for the dealership to mail them a warning letter, because that letter is never coming. It's the guys who figured somebody would've told them who end up on my lift. And I want to be clear, because this part matters. Maintenance has nothing to do with it. I've torn down motors with barely 30,000 miles on the clock. I pulled apart a Tahoe last summer with 24,000 on it. Practically a brand new truck. Owner had it less than a year. Spotless oil. Best synthetic money can buy, changed early every time. Made no difference. I've seen guys with full dealer records, every interval stamped. Made no difference. The oil changes were never the problem. The pin was. And no amount of babying that truck stops that pin from cycling every single time you drive. That's the part that eats at me. These are good motors. Take the AFM out of the equation and a 5.3 or a 6.2 will run 300,000 miles and never blink. So a few years ago I started telling every single owner who comes through my doors the exact same thing the smart guys already knew. Get yourself a FullForce disabler. It plugs right into the port under your dash. Couple of seconds and you're done. It just tells the computer to leave every cylinder running, full time. No more cycling. No more beating those lifters back and forth every time you turn the key. It doesn't reprogram anything. Doesn't touch your tune. And unplug it before a dealer visit and there's absolutely zero trace it was ever installed. I've had customers come back at 40,000, 60,000, 80,000 miles after I put one in. Zero issues. The trucks run smoother. And the lifters aren't getting beaten to death every single drive. I won't sit here and tell you it's magic. A lifter that's already damaged is a lifter that's already damaged, and this won't un-ring that bell. But it takes away the one thing causing all that wear in the first place. That's the whole game. You don't need a five-thousand-dollar delete. You don't need an expensive tune. You don't need to tear anything apart. You just need to stop the cycling. I'm not writing this for any company. I'm writing it because I'm tired of watching the guys who didn't know pay four and five figures for it. I'm tired of being the guy who has to break the news. I'm tired of knowing that the guys who did know fixed the whole thing for the price of a tank of gas, and the only difference was that somebody told them first. If you drive a Silverado, Sierra, Tahoe, Yukon, Suburban, or Escalade from 2007 or newer with a V6 or V8, you've got AFM. You've got those lifters, and they're cycling every single time you drive. So be the guy who already knew. Not the one I'm scraping metal out of next month. EDIT: A bunch of folks asked, so here it is. The one I put my faith in is FullForce. This is where to find it: https://www.tryfullforce.com/products/fullforce™-afm-dfm-disabler They back it with a 60-day guarantee too. I've handed out more than I can count and not one's ever come back to me. Not one. See less
    • Thanks for following along. I'm not author material, my tenses are all over the place and an editor would have a heck of a time cleaning up after me. Reading and writing is still a fun pastime though.   My new scanner came in yesterday, wow, where the heck has this thing been?! It connects right up to the Blazer, there's all kinds of bidirectional tests like EGR activation and percentage, toggle the fuel pump relay, EVAP purge valve, IAC control, AC relay, reset the transmission's adaptive learning, toggle shift solenoids and TCC lockup, and I can reset fuel trims with the click of a button...all things I could have used over the last 60 days!   It's also telling me there is a stored code in the ABS module for front left wheel sensor open and something about the brake switch. The ABS dash light works. It illuminates normally during the self-test at key on/ start and that's it. I cleared the codes and will see if they set when I take it out later. That, and I'm going to get (hopefully) real data on timing and cam ******. The PID's are there.   I connected the tool to my truck...holy smokes. Newer vehicles make early OBDII vehicles look like 8-bit, pixelated, early Nintendo stuff. This? This is like wearing 3D virtual reality goggles playing one of those elaborate, cinematic video games with seasons and plots in comparison. There are SO MANY modules and SO MANY tests and SO MUCH data. There's a scanner sequence for filling the coolant...   End of the day, it's a tool with way more power than I need, but the versatility to do old and new is there (and I need an adapter to connect it to my OBDI Camaro). It will allow me to do the first pass of diagnosis when out-of-warranty vehicles need help, and it will enable more DIY maintenance like brake system bleeding, ABS bleed, etc. I probably over-bought here, but, mission is accomplished.   Enjoy your Sunday...I need to shut this machine down and go get ready for the week ahead.
    • Not that I've read, after all the issues they've had in the past I'm pretty sure they learned their lesson.
