Another CAI question
SquireSCA
23 hours ago, Nitrousbird said:
How would a CAI improve your throttle response? There are only three things an intake "could" do and many don't:
- Reduce the restriction of flow
- Lower IAT's by either insulating the charge pipe from engine heat or pulling from air more directly from outside the engine bay where it is cooler, resulting in more dense air
- If a ram air setup, possibly forcing air into the motor at speed (which would also help the above).  There are very few true ram air setup out there and few are actually effective.
If you look at the CAI's for these trucks, none are insulated or pulling air from a different source. At best they are providing a less restricted path.  This may improve WOT power but throttle response is controlled by the ECU.
Think of a truck carrying a load of 1000 lbs. vs a truck carrying a load of 200 lbs. Which one would feel like it moves/accelerates faster, feeling lighter and having perception of a better throttle response?
  • Replies 47
Just now, 3tspapat said:
Think of a truck carrying a load of 1000 lbs. vs a truck carrying a load of 200 lbs. Which one would feel like it moves/accelerates faster, feeling lighter and having better throttle response?
And please explain how a CAI would do any of this. Not bullshit seat of the pants crap, but an actual improvement of HP/TQ when not it WOT situations.
ECU monitors airflow and adjusts fueling accordingly. Only at or near WOT, where the intake could be a restriction, would a benefit be seen. Anything else is in your head to justify the purchase.
Glad you asked!
The truck now weighs less because your wallet size has decreased in weight because you just blew all this cash on a CAI...so it's more responsive on an infinitesimal scale.
I have one...but I know it doesn't do much if anything at all for a stock motor, no tuning, etc. I like the sound it makes when I accelerate hard, which is like 2x per 300 miles because that is how I like to drive. Do I feel like I wasted my money? totally!
Les restriction makes a difference, been proven over the years over many platforms. Don't understand why you guys argue about it. Now Silverado/sierra aftermarket intake design that is a different argument, most designs don't work very well. That said the well engineered ones work. Just most trucks will need a tune to maximize.
 I would fix the inner lip on the throttle body first. Also dump the factory cat back.  Open intake/open exhaust with tuning is the basic foundation of engine modification, that is sound practice not some kind of snake oil. You choose lame products that don't work or don't do all the mods needed to get a noticeable result it's your fault. These trucks wake up with the right mods. Just throw on  K&N filter and a flowmaster - ah no. Takes more than that.
I always upgrade to chrome valve covers first. They're always good for another 5 hp. :devil::smash:
Well at this point I have:
  • Made straight pipe from the CAT's back.  No restrictions, no muffler or resonator.
  • K&N high flow air filter(minimal oil applied so as not to mess up MAF)
  • Airaid MIT
  • SuperChips Flashpaq F5 with 91 octane Performance map, trans optimizations, 20% throttle sensitivity added
I am not that far from Vengeance Racing... I could always book some dyno time to see how the power curve and AFR is doing, and have them custom tune it if needed...
Put a truck with no CAI on a dyno then install a CAI on same truck and run it on same dyno and the run with the CAI will show more hp/tq guaranteed. Doesn’t matter if it’s not enough to feel, all that matters is there is an improvement.  Combine that with a tuner and a less restricted exhaust  and it will definitely make more power then if you just tuned a stock truck with own intake and exhaust.
  • Airaid MIT
That's awesome you live so close to Vengeance. I live in Social Circle, GA. They are doing my Whipple Supercharger on March 18th (made the appointment in December and that was the earliest available.) They are one of the best performance shops in the US.
Yeah, they are like 20-25 minutes from here.
Love your bike pic. I had a 2015 Duc 1299 Panigale. They sure have refined them since then. Do you do any track days in Braselton?
Yeah, done several and I am signed up for another track day on May 4...  Not sure if I will take the Panigale or the Aprilia...  The Ape is faster and has better electronics, but the Ducati is better aero and more set up for track riding... probably less work too...
I did a couple N2 track days there last year. Thinking about signing up for the one they have on 06/06. I already have track plastics on my S1000RR and Metzeler Racetecs RR and will probably keep them on till then. Sorry to derail your post. Good luck to you and nice bikes.
No worries on off topic stuff, it's all good.
I don't bother with race plastics, I just take my streetbikes to the track once a year, maybe twice.
2017 1500 LTZ Z71 Silverado.
I ran mine a month so I could learn it's base lines and let the ECM learn my driving habits.
12/19 city/hwy mpg (pre-mod)
Installed K&N CAI and AirRaid throttle body spacer after 30days.
16.4/22 city/hwy mpg (post-mod)
Sure, a lil growl under the hood came out, always fun, but the fuel costs savings will pay for itself after 10k miles.
I'm thrilled.
    nolankd
    nolankd
  • Who's Online   2 Members, 1 Anonymous, 438 Guests (See full list)
    • For a limited time, retail accounts receive a free fender cover (G2803) with their order of $750 or more when they use code FENDER926 at checkout. The promotion runs through Sept. 8, 2026. Own a business and want to apply for a retail account?  Apply here. https://www.amsoil.com/business-opportunities/sell-in-your-store/?zo=521390
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
