It's here, well sort of...
My NEW ride is at the dealership, wow what a beauty, and the FIRST red one I have ever seen, I special ordered it, placed the order back in December, and it got here the other day..... be a few days before I can pick her up, as they are doing the pdi stuff, and adding a couple extras, and that's ok,  as the roads are still filthy and so is the weather..... probably going to be my last BIg purchase, so I want her right and to last..... as you can see . she still needs a bath and some detailing, but she is mine !
Congrats! Looks awesome! I also saw a special order red Tahoe sitting at a dealership once and looked pretty sharp. Enjoy the new ride. :)
THANKS  guys......I really appreciate the comments,  I am thinking this siren red is a rather rare beast, certainly for the dealerships for 'stock', not one on any lot anywhere in western Canada, that I could find.....she should look ok in the sun ............ and hopefully not too much like a fire truck ! :P
Somebody has a Suburban of this color in my neighborhood, and that's the first thing I think when I see it is fire truck! LOL
Yeah, dealerships never stock this color. The neutral/bland colors are the easiest to sell, so that's what they stock. I'd have preferred a blue myself, but was shopping for a closeout 2018 in dealer inventory, and couldn't find one in that color with the options/config I wanted, so settled for a Pepperdust with the exact options, minus the 22" wheels, but they look nice. :)
Thanks, if it looks like a 'Fire truck' I hope it looks like the SUPERVISOR'S truck LOL!!!  It is a color that I don't think I will get tired of, and yes I like the blue as well.......Pepperdust is also an easy one to do.....and yeah the neutral/bland colors are all the rage these days it seems, the sales manager told me he has never sold a red one, ever, and the main ones folks buy are the black and white ones........I love black, had a black IROC Camaro, couldn't keep it clean, not good for a daily driver in the crappy weather, so that was out....and I already had a white one, so that was a second choice, and I like this red, so that was the first choice.... lol..... I think I'm going to really like it, going to be a bit of getting used to, to go back to full size, but I'm up to the task.....
On 3/22/2019 at 10:49 AM, Mandalorian said:
What interior do you have?
Black perforated leather.... the Mrs, wasn't keen on the brown and the other colors really didn't do the truck full justice...she's mine now !
There's one red one in my neighbourhood. I don't think it looks like  a fire truck. The tint coat differentiates  it from the red in a fire truck which is more bright. I have black leather  and it looks awesome.
Personally I don't think it looks like a fire truck, but some guys have mentioned that... maybe in jest.....in the sun it just pops......do we look like 'proud parents'?? LOL!!  It is an incredible piece of kit, I'm still learning about it, and I must say, the Borla pipes sound just perfect...... I'm lovin this rig....
I love the roar of the v8 on the suburban. And 6 speed tranny shifts  smooth  on acceleration like a tried and true  transmission. The fuel economy  for this beast  is phenomenal for its  size. I got a silver one . Many said i should go for black . And black looks mean and like  a limo. But i prefer the utility  of silver ice metallic. It reflects  the sun keeping vehicle  cooler in summer on top of it already being so well  insulated and it hides dirt and scratches  so well.  There's too many black ones on the road. Its nice to see other colors.
Around here, most people see a black Suburban and automatically assume their Uber has arrived.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
