Hey guys looking to swap out my stock lights for hid or led but can't find what size they are, can anyone help me out.
Low beam bulbs are H11
High beams are 9005
I just installed a 4 piece set of LED lights from Sealight on my '19 Silverado Custom Trailboss.
Just make sure you buy mini or low profile bulbs as most of the LED bulbs have the large cooling fans with heat sinks mounted on the back of each bulb and you won't be able to reinstall the dust covers.
Whatever you buy, make sure the bulbs are low profile as there's not as much room directly behind the bulbs like on previous years.
My '14 Silverado Rally 2 I just traded in had room for the large cooling fans on the rear of the bulbs. But this isn't the case with the '19's.
These are the ones I just installed in my truck.
I bought the 9005/H11 4piece set.
What a difference in color and brightness.. 110% better.
https://www.amazon.com/gp/product/B07MNG5S5P/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Hope this gives you an idea of what you need to change your headlights out.
In the photo the left are the stock bulbs and new LED's on the right.
  • Like 5
  • Thanks 1
High beams are 9005
Looks good
  • Thanks 1
High beams are 9005
It looks like a lot more glare coming off the right side.  Maybe it's your camera angle, but if it's your beam pattern oncoming drivers are going to hate you.
-Dave
-Dave
Hey Daverado,
Naaaa.. no one hates me yet. ?
I took numerous photos trying to get the true results of the headlights but it was tough. The camera shot doesn't do the headlights justice.
I marked my garage door with tape exactly where the halogen beams hit and then compared the LED beam once I swapped them out and they hit in the exact spot.. I've had zero issues with anyone flashing there lights thinking I have my high beams on like the previous LED bulbs I installed on my '14 Silverado. With those I ended up adjusting those headlights down so as to not blind anyone. The new Sealight bulbs have great reviews so I decided to try them and I'm very happy so far.
  • 1 month later...
High beams are 9005
Did you have any issue's with the drl's with the sealight led bulbs?
No issues whatsoever.
There's no flickering or any other issues with these bulbs with the DRL. I'm very satisfied with them so far. I would highly recommend them.
I didn't have to readjust the headlights after installing them like another brand I used on my '14 Silverado. With masking tape, I marked the beam pattern on the garage door for the stock bulbs before I removed them, then after installing the new bulbs the beam hit in the exact spot. There was no readjusting the headlights. I can't say enough good things about these bulbs so far.
Very quiet running fan in each bulb. Two thumbs up. ????
High beams are 9005
is the color white or yellow? hard to tell. appreciate the info.
Any issues thus far?  Radio interference?  Do they get hot with dust caps back on?
No issues whatsoever so far, No radio interference, I'm very impressed with them so far. ???? I was just camping in the Florida Keys last week along with the truck and there were no issues with overheating headlights but I didn't actually feel the dust cover to see if they were hot. I can imagine everything under the hood was very hot being 88 degrees and humid all week. ?
Hey LeadUtensil,
The color of these bulbs show as bright white. The stock bulbs are dull yellow and we're terrible trying to see at night.
High beams are 9005
Looks really good! My question is, the new bulb set you bought, are they plug and play? Just as if I were replacing an old bulb...
Yes they are. Unplug the stock bulbs and plug in these. Same connections
    tonyb2760
    tonyb2760
  • Who's Online   6 Members, 0 Anonymous, 320 Guests (See full list)
