IIHS front tests are out
3 minutes ago, Sierra Dan said:
Better?  You know what they say....  Beauty is in the eye of the beholder.
Go check out the Bilstein thread on the K2 2014-2018 section.
Any aftermarket shock is better than the factory Rancho.
Mine's a T1, was told it's improved.. with that being said, could have been the transmission downshifting that caused the back end to shift, along with inferior shocks.
I am having the transmission checked out.. the dealership even asked me if it's given me jolts and suggested it may not be shocks. The poor terrain I was driving on contributed to that, but they conceded it shouldn't have happened.
  • Replies 34
If you looked at crash test scores for car seats, would you pick the one that was rated good or the one that was rated marginal? I know my father would say if the marginal one was on sale he would buy that because it was still better than when he was a kid and they didn't even wear seatbelts
Sent from my Pixel 2 using Tapatalk
Bouncing rear ends in this thread to, I am having bouncing rear end nightmares. Go buy a Ridgeline and get no bouncing rear.
Sent from my ONEPLUS A6013 using Tapatalk
As I understand it, IIHS only started testing passenger offset in the last couple years. Blindly thinking your K2 will be any better for your wife’s legs may be foolish because it wasn’t tested. It could very well be worse.
Don’t take my word for it. The T1 is much improved. If the K2 was tested for the passenger offset, it would likely fail miserably because they designed it without putting any effort into a passenger offset test that didn’t exist.
Is it as good as the Ford? No. Is it better than the last one, yes. Would I buy a Ford to prepare for an accident that likely would never happen? No. Life is full of risks. Take your chances every time you drive anything.
Thanks for pointing this out.
It's good enough, but isn't it getting tiring with GM just being "good enough?"  Every new generation of truck for the last 20 years they've needed to become class leading, and every time they've managed "good enough."  I'm afraid this time it may cost them as FCA is breathing down their necks and they are beating "good enough."  Might as well forget about ever being good enough to catch Ford.  Disappointing.
Coming from a 2016 Ford F-150 XLT, I'd say my 2019 Silverado's interior has slightly better feel. Could be due to the RST trim.
One minus about the Silverado is the rear end hopping off the road, I didn't have that with the Ford so I"m a little disappointed here. But, if it weren't for that, the Silverado is better in more ways than the 2016 Ford F-150 XLT.
Lol, You and your rear wheel hopping
Sent from above
Not that I’d ever be interested in that poop bucket. I heard they’re discontinuing the Ridgeline due to horrible sales.
Sent from above
 Ford took a beating in the media when they rolled out their new F150 as their crew cab was better than their extended cab in the frontal offset crash testing. The ext cab got the additional floor protection the following year. So GM knew well in advance this was a test that their truck would be subjected. As someone else mentioned, good enough is getting old.
Since the F150 is the only safe truck, I went and drove a $55k XLT tonight. I got news for my wife, I think she is going to have to get used to one leg. I just can't see myself buying an F150. A $55k XLT with the 3.5 L the interior felt like a work truck. The Silverado offer so much more for the same price MSRP with bigger incentives.
Yes, and it turned out to be a very small modification needed and now the crew cab is similar to the extended cab. That happened +back in 2015 when it first came out.
Agreed, incentives are bigger and I do believe Silverado has much better interior compared to F-150. I'm very happy with mine.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
    • You refuse to own anything made in this century yet you reportedly own... a 2007 Silverado, which is now almost 20 years old. The dissonance.... turn up your hearing aid?   You clearly don't understand the government contracting process, brother. We send people to die on front lines, keep the public safe, and make people's husbands, wives, children enter burning buildings with equipment from .....wait for it.....   ...the lowest bidder....   Just because something is used for a long time doesn't mean it's good. But it might be cheap and plentiful.   Please, continue to whine about new trucks in a thread dedicated to new trucks, which you've said you'll never own. We get it. Go tell everyone how you're stuck in time on a Panther forum. I mean, Jesus, an 86 isn't even one of the good Panthers.
