Started out earlier this week with the truck thinking the driver's door was always open and the window switches in the driver's door not working. I pulled the door panel off, checked all the connections but I didn't find anything obviously wrong. Now that I have put it all back together, the truck thinks the door is always closed and the window switches in the driver's door still don't work. The radio does not turn off and the dome lights do not come on when the driver's door is open. The locks and mirrors work as they should. Any ideas where to start or what to test?
You probably need to replace the driver's side window switch. It communicates with the BCM to control both the windows and the door open switch; I don't know if it does the locks.
I wiggled the harness and door jam connector around but nothing changed. But now I've opened and closed the door a few times and its back to thinking the door is always open
i remember reading that there are issues with the door harness chafing.  id think to pull the panel again and go over all wires and look for fraying.
Un plug the connection and to can use a digital multimeter and set it to fuse test. It will make going wire for wire much faster. I pulled mine all the way into the large speaker hole to get new wires feed through.
I pulled the door jam connector though the speaker hole last night and found the LIN signal wire (green/yellow) completely broken. The large black (ground?) and red/blue (power?) wire had broken insulation as well. I patched them all up and everything seems good now. I'll probably just replace the harness at some point. The hard turn the harness makes to go into the door seems like a really obvious problem point that should have been addressed a long time ago.
Door passthrough wiring is always a problem aria.. The wires move every time the door does.. I  was going to suggest you look there, but you found it yourself.. Nice work!
Question, tryna figure out why passenger door power step don't come out, could it be a door ajar issue, I got a 2015 Silverado LT  5.3l. I got no open door chimes or indicator on my lcd screen
  • 9 months later...
Hey were you able to fix this problem and if so what was it? My 2015 Silverado LTZ is doing the exact same thing. At the moment the door doesn't read that it opens, the dome light doesn't turn on when I open the door, the radio stays on, the driver side window doesn't roll down. Sometimes when it does work the DOOR ADJAR would stay on all the time even when the door was closed and the driver window sometimes rolled down and back up. I would wiggle the wires at the door (when door is wide open) that lead into the cab and then it would roll all the way up. As of now, the door doesn't read at all, driver side window doesn't roll down (but the switch rolls down all other windows), radio stays on... any tips?
  • 4 months later...
i am having that very exact issue
2017 Sierra 3500 Denali HD
anyone?
  • 9 months later...
I'm having same issue..2016 Sierra 1500. Door ajar always showing, master switch doesn't work for windows but locks and mirrors work. So I exchanged switch for new one, nope.  Disconnected plug to motor and have constant 12v to top left of plug but not top right. I tested connectivity to motor (from the 2 prongs in plug receiver and nothing. I ran direct power to the motor by 12v battery to the 2 prongs and nothing. Suggestions?
Hey, were you able to fix this problem, and if so what was it? My 2015 Silverado LTZ is doing the exact same thing. At the moment the door doesn't read that it opens, the dome light doesn't turn on when I open the door, the radio stays on, and the driver-side window doesn't roll down. Sometimes when it does work the DOOR ADJAR would stay on all the time even when the door was closed and the driver window sometimes rolled down and back up. I would wiggle the wires at the door (when the door is wide open) that lead into the cab and then it would roll all the way up. As of now, the door doesn't read at all, the driver-side window doesn't roll down (but the switch rolls down all other windows), radio stays on... any tips?
My truck is having this same issue.  I was looking for a answer to Carlos Plata's question and did not see one.  Did you find out what the problem was?
I did not fix my issue.  I still have the truck and drive it almost daily.
My door ajar issue got very sporadic and intermittent.  I’m thinking it’s a wiring issue because it really went bananas after a couple of rainy days.  Then when all the rain stopped, so did the intermittent issue.  So now I believe whatever the problem is, it is outside.
Then, it failed completely and luckily it failed in my favour with the door closed and window up.  So the truck thinks the door is permanently closed.  Now although that door doesn’t register when it is opened… I don’t have to deal with all the dash dinging and all the lights/door ajar warnings.
Whatever the failure is I’m suspecting it’s one common location with all of our trucks.
 The other commonality is, whatever is causing the door issue is linked to the windows, because although my door shows as closed, that window no longer works.  I tested the window motor and switch, they’re both good!
so to summarize, whatever the issue is, my theory is that it is outside and common between the door and window.
So what did you find when you checked the wiring? Were there any broken or chafed wires where wiring passes out the door to the connector?
Edited by mikeyk101
    • I have a 2024 Chevy Silverado 2500 with the 6.2 liter engine, Vin: 2GC4YME79R1273849, with 27,437 miles. Recently we took a trip from Candor, NY to Townsend, TN pulling our fifth wheel, when I got close to the Townsend, TN area The truck gave me a message of low oil. I checked the dip stick and found it was 2 quarts low. Today, August 27, 2026, I had the oil changed and the technician Found the truck was very low on oil.  Is there a Recall for this? What is my recourse for this issue? Do I call the dealer where I bought it or any chevy dealer?   Robert Strickland 292 Owego Road Candor, NY 13743 352-502-6588 [email protected]
    • We understand the importance of understanding how your Sierra performs, @SoCal Angler. Our team would like to gather the proper details to assist you with your inquiry about your truck's automatic braking. When you have a moment, please visit: https://s.chevy.com/support-request and fill out the request form with pertinent details. This will ensure your request is routed correctly so we may take a further look. We will keep an eye out for your outreach.
    • That is the funnel kit I bought and for being here in Canada I did get a better deal than what other sources were charging through a certain supplier in town that sources more directly and they ordered it for me. There are other items now on the market which would be perfect as well but this has worked well which was the hope when I bought it. I mentioned the Amsoil quart bottles as they have that squarish shape up top and it props nicely on the rim of the opening without falling into the funnel so I can leave them sit and drip a bit. You may have already figured out that to get the cap off the valve cover unless one is 7 + feet tall its not going to be reached without standing on a step of some sort and so when I do that I put the right adapter in and just leave the elbow on the funnel all the time anyway and open the lid and then if using quart containers for sure I can stand beside the truck and leisurely add the oil, and I can leave that funnel on when starting the engine to let it idle to fill the filter and then add the rest of the oil to top it up before removing the funnel and putting the factory cap back on. I put the cap back on the top and slide the bottom cap on as it fits onto the elbow adapter also and then store the funnel in a clean household plastic garbage bag along with the adapter so I have no reason to be washing out the inside of the funnel as I keep it completely clean between uses.    Draining the oil as per the under the truck portion, yes indeed that is slick as someone was thinking on GM's part there and admittedly I don't drop the oil screaming hot in this truck due to the exhaust being there and makes it safer as far as the oil temp if its just warmed up some instead as I don't have the truck on any ramps etc as I do it as the tires sit on the garage floor. The filter is not boiling hot then either and can drop it off into another pail after pulling the drain plug and just leave it drip out. Go back under a few hours later with new filter in hand and clean off the filter base and put the new filter on and install the drain plug. The filter is a little cramped in there as per wrapping ones hand around the filter and I am so used to using the band style filter removal tool that its no big deal and same for snugging it up. My filter wrench is many years old now but I think this is the current version and sounds like the right size, just in case my explanation was not great ( those nylon strap wrenches that one tool fits all filters are not my favorite tool to use, I much prefer this style personally )     57020 Swivel Gripper - No Slip Filter Wrench - Small | Lisle Corporation   And again about the oil draining and filter setup under these GM trucks, I've watched Ford videos of them struggling with oil flying sideways out of the oil pan on the gas 7.3 due to the sideways drain plug onto other components or cross members and guys trying to make shields out of carboard etc and other Ford pickups that Ford insisted they have sideways drain plugs. One win for GM there anyway with this engine.
    • Kind of off topic, wife drives a 2023 Yukon Denali with the 3.0, been a great rig so far, incredible fuel economy for a truck that big and heavy. Coming up on 50000 trouble free miles.
    • I`m gonna try some of this in my 2000 LM7 that has had the famous piston slap since 17,000 miles or so. I have used Mopar combustion chamber cleaner down the spark plug holes a few times in the past. Corrects the problem for a few months or so. Then returns. GM top engine cleaner has been used also. No good results from this.   This LM7 never used oil. Even running the piss out of it.   Course, I`m gonna use this in my 2025 L84 while it`s still clean. It`s got 13,000 miles. Used Chevron fuel system cleaner [2 bottles in tank] a tank or 2 ago.
