Anyone know if the Sierra hooks and Silverado hooks are interchangeable? The rough country site says it won't fit my truck but I can't imagine they are different.
 Will not work.  Sierra hooks are vertical, Silverado hooks are horizontal.
On 2/22/2020 at 4:57 PM, Flatblack83 said:
No more gay stock tow hooks..lol
You have a link for these?
On 3/6/2020 at 4:30 PM, lapoolboy said:
What do you guys think of red tow hooks to complement the red of the Z71 badges?  Yay or nay?
Yay for the red hooks, maybe black bow tie too?
I thought about this too, but the wheel center cap bowties are gold and the steering wheel bowtie is gold....would drive me crazy not matching!
I like the idea of the red tow hooks to match the z71 emblem. As far as the center caps and steering bowties, there are kits on ebay that changes them to red.
On my 2014 (2 trucks ago) I had those little bowties painted black too! Well, the ones on the center caps, not on the steering wheel. It looked great!
As for the red tow hooks...I vote nay.
In fact, I just received a black set of tow hooks in the mail today. I'm getting rid of my red ones asap.
Well, I would have bought your red ones!  I just ordered some!
How much do you want for your red ones? PM me!
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,245 Guests (See full list)
