April Incentives
Does anyone know what the April incentives are on GMC Sierra 1500’s?
  • Replies 37
We’ll know in the am. March incentives ran through today
the ram discounts and grand slam interior = best sales ever so far
https://www.tfltruck.com/2019/04/ram-trucks-increased-sales-in-march-but-most-other-trucks-are-declining-sales-report/
After 3 months, they are outselling the SILVY..  SIlverado is down 15% YOY so far . not a good sign as the Sierra is also down 2% YOY..While Ram is up 15% YOY
I know GM started later with their new 19+ models and 3-4 months is small sample size to judge a product  but you cannot deny RAM has an appealing product . Next 3 months should be interesting .
It is hard for me not to look at the 2019 Ram for my next truck. Their pricing is amazing but I still question the quality. I am expecting and will hold out for some good incentives from GM in the next few months on the T1 once the limited models are gone.
I have 9 months left ou n my denali lease. Thank God I leased it because it's been in the shop about 12 times for major and minor issues, leaks, tcm failure, all injectors replaced 2 times now ect.....
When I replace it I will be paying cash for the truck and I will be looking at the Denali, ram limited, and raptor with the new v8 hopefully. Which ever I like best and has the best price I will be purchasing. All brands will have issues and lemons so it's really luck of the draw. I'm hoping incentives on the denali are there and my father in law worked for GM so I get that discount too. Hoping it will work out.
My 2017 denali I got in feb 2017 and got close to 20k off. Stickered at 67 got it for 49 something.
Why were your injectors replaced?
The truck at idle would surge from 400 to 800 rpms and you could feel it jerking when stopped. This happened 2 times. The second time the truck was in for the shake and the service advisor noticed it and did it while the truck was already there. It seems like it is starting to do it again as well
Sent from my SM-N950U using Tapatalk
Whatever you do make sure you check the VIN number and build sheet. If it starts with a 3 it's made in Mexico. If it has a rear slider window get one made in November or later to not an early made truck like mine that after one day in my driveway had a soaked interior from the rear window leaking issue.
In general the last 6 digits of the VIN is a sequential number. Starting at 100000. So if your truck is 107xxx, that means it's the 7,xxx truck made at that plant (I think). I am sure someone will correct me if I'm wrong.
Because Chevy and gmc had no incentives until March really, there is a lot of inventory on dealer lots that could be an early build like my truck made in August of 2018.
Otherwise good luck.
Sent from my Pixel 2 using Tapatalk
I am leaning towards ordering a truck with all the options I want! I have done that with the past four trucks I have purchased and I have been so much happier with them.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
    • You refuse to own anything made in this century yet you reportedly own... a 2007 Silverado, which is now almost 20 years old. The dissonance.... turn up your hearing aid?   You clearly don't understand the government contracting process, brother. We send people to die on front lines, keep the public safe, and make people's husbands, wives, children enter burning buildings with equipment from .....wait for it.....   ...the lowest bidder....   Just because something is used for a long time doesn't mean it's good. But it might be cheap and plentiful.   Please, continue to whine about new trucks in a thread dedicated to new trucks, which you've said you'll never own. We get it. Go tell everyone how you're stuck in time on a Panther forum. I mean, Jesus, an 86 isn't even one of the good Panthers.
