All,
I have a set if OEM crew cab running boards for my 2017
Friend of mine has a double cab 2017...hurting for $ and I'm willing to give my boards to him.
Will they fit minus cutting them down on each end and reinstalling the plastic end caps?
The crew cab boards have 4 mounts - how many does the double cab have?
Can anyone measure the overall length for your double cab set?  Maybe the mount points  where the boards bolt to the mounts?
Thanks
I would just test fit them on his real quick. It honestly shouldn't take more than 30 minutes to try. I would assume they wont fit since I don't think theres any adjustability like aftermarket ones. My double cab tubular has 3 mounts, but the body have a hole for a fourth that is unused.
there was a thread or a post in a thread where a guy took the Denali tri-mode steps from a crew cab and modified them to fit a double cab. I think he just had to cut off the rear of the top bracket that mounts on the truck.
22 minutes ago, HeySkippyDog said:
They should fit just fine. Wheelbase is the same.
Sent from my SAMSUNG-SM-J727A using Tapatalk
Wheelbase is not the same...Sorry forgot to mention mine is a crew 6'6" bed
OK...I'll give it a shot.
Thanks
What does the wheel base matter?.
Cab size is what matters here.
Crew cab is 9" longer than a double cab
They are both built on the same length chassis in the case of a crew cab short bed and double cab standard bed.
OP has a standard bed with a crew cab, but his running boards are no different in length than one might find on a crew cab short bed.
As such, the boards cannot be "too long". They will not hit the back tire, because wheelbase is the same on double cab/standard bed and crew cab/short bed.
Go to a site that sells running boards and find a set that fits your truck.  Put in your friend's truck specs and see if the same part number for the same boards comes up.
He's talking about taking boards off a crew cab and putting them on a double cab
The cab on the double cab is 9" shorter than the cab on a crew cab.
Crew cab boards are 9" longer.
I should know I have one of each. Sure the longer boards will fit but they would look stupid
Edited by dieselfan1
I don't know, the extra length would go over to the bed, that could be a handy thing. But I am function over form on a lot of things.
It would look stupid
He can cut them with a metal cutting chop saw and just use three brackets. Easy .
[emoji2369] I think I'd try them on as is before I did anything permanent. What'll really look stupid is making a bad cut and dorking them up. Nobody will be using them and you'll be out the money.
Probably won't work.. There are only 3 mounting brackets on a double cab if I recall correctly... You can get running boards on ebay for $130 that look just like OEM, your buddy should just save up some $$...
Those $130 ones are junk
    ShipOfTheseus
    ShipOfTheseus
  • Who's Online   2 Members, 0 Anonymous, 740 Guests (See full list)
