Ya one of the many electrical issues We ve seen at the dealership I work at.  Just plagued with issues this generation.
Have you found a fix for it?
Light went back out after driving for 10 miles. Called dealer this morning and they told me unless the light is on there is nothing they can do. Starting to get really frustrating.
Negative, but some of the mechanics think its a bad ground somewhere
The code that was originally pulled the first time I took it in was C15A9. Is that similar to the codes you've seen on the trucks that came in?
yes as well as C05D2 & P25A2, been seeing few trucks coming in with oil pans leaking aswell as the rear diffs.
Thank you for your knowledge. Now I just have to try to get the truck to the dealer next time it comes on before it clears itself.
I know this sounds dumb but the leaking oil pan and diff is under warranty?
Yes, we've had 3 trucks and done them all with no questions asked. Our dealerships always tries to go above and beyond.
Edited by Pinnacle
Nice. It's hard to find good dealerships. This is my first brand new truck and I love it besides the 4wd so far. I hope I dont have more problems
New owner of 2020 AT4(1 week old), and my service 4WD light came on last night on way home from work too.  I was in AUTO when I noticed it.  Was still on this AM.  I restarted truck and it wasn't there.
Dealer told me that it has to be on for them to see, but they didn't know the carbon bed was different than a regular bed....SERIOUSLY!!!
19 hours ago, CNADN SIERRA said:
Maybe I should have bought an F150..........?
I cringe when I hear people say that, and Im apart of every forum GM FORD RAM TOYOTA as I have worked for all of them as and adviser.  FORGET the top 3 and ONLY buy as we in the industry call them the "TANK" Tundra, nothing else comes close best built truck period.
Light came on again when I pulled into my driveway. Hopefully the light stays on for the trip to the dealership tomorrow morning. Would have taken it right there but they said they dont have any loaners available or anyone to give me a ride to get a work truck.
Edited by 19Sierra
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 701 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
