Another FNG
iaa4130
Just wanted to introduce myself my name is Ian, My SN is my initials and the 4130 is the periodic table of elements for Cro-moly the material they make BMX bikes out of. I just picked up a 14' Silverado Rally Edition and I'm loving it!!! I already can't leave it alone like anything else and want to start modding it, So I have that going for me.
Thanks. I’m looking forward to learning about the Silverado, I had some Tacos, Jeeps,  etc etc prior to the Silverado.
Well that's not how I wanted to start my day yesterday.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
