Just now, Truckboy said:
So do you think it’s best if I just buy belsteins and put them on instead of having dealership replace them with new ranchos?
Is the dealership willing to replace the Rancho's?
Not sure yet. Going to call them Monday. But like I said I did buy their protection plan for $4000 and it is suppose to cover it so they better. Not just that, I just bought the truck on Tuesday, it should be under their 1000 miles/30 days warranty still.
Yea, that is a lot for an extended warranty, hope that they treat you well.
Post how the encounter goes, and good luck!
Thank you.  Will see how it goes.
You are very welcome.
So dealership(Lincoln) said they couldn’t find anything wrong. Everything is in spec and no leak on the shocks. Service tec told me that’s just how the Z71 suspensions are. It’s probably just a characteristic of the Z71 shocks. I said okay, let me test drive another Z71 and see if it’ll have the same problem. So I test drove another similar truck with the service tec in with me and no issues at all. That was a clear reason/sign that there is clearly something wrong with my truck. It’s not the Z71 shocks. So at the end of all this, they pretty much said sorry we can’t fix it, nothing broken. Go to Chevy.
I also called Chevy and spoke with a service consultant. Explained to him what I am experiencing and he said no, your truck should not be jumping to the side when going over bumps or potholes. So now I’m going to take it to Chevy and hope they can find the problem.
Oh and they mentioned that it can because of my 22inch rims/tires that is causing it to jump. Is that true?
Edited by Truckboy
Do  not think so on the 22"s, have them on my 18 and were on my 16, both factory wheels, both trucks LTZ Z71 models. Both rode fine.
Some things I would check are tire pressures, did the previous owner do any suspension mods, like adding an extra leaf, air bags, spring helpers, and so on. Any of those would really stiffen up the rear of the truck, causing what you are experiencing.
Sounds like you are not off to a good start with your extended warranty, can you still get a refund for it?
Tire pressure was at 45 when I first brought it in. That was the first thing they tried. Lowered it to 33-35 and still have the issue. I mean it’s probably not as bad as it is on 45psi but still having the problem. As for the previous owner, I’m not too sure. Maybe that is something I should’ve asked before buying..
And at this point I might as well keep the extended warranty because for some reason I feel like I’m gonna have some transmission/engine problems real soon Because now I am noticing a “clunk” when decelerating in low gears and coming to a stop.
I’m starting to regret this purchase. $32k with issues. I should’ve just gotten a tundra..
Edited by Truckboy
Get bilstein 5100. REALY helped my truck but its also tire pressure
Should I even go get a second opinion from Chevy themselves or do you think it’ll just be a waste of time since there is no leak on the ranchos. Rear end is jumping and according to Chevy service consultant that is not normal and shouldn’t be happening. What the hell do I do at this point?
Also were you having the same issue as I am? Rear end jumping or swaying to the side when going over potholes and bumps?
Yes
I wasn’t having problems with my winter rims and tires
Only the summer ones. I think it was a combination of shocks, air pressure to high and tires getting harder. NITTO Ridge Grapplers. I run 40 psi now. Only 15000 miles on tires but they suck in rain. Almost fishtailed into another car while driving on the highway
6 hours ago, REDOO2000 said:
Yes
Yeah dealership lowered it to 35psi but it is still jumping. Did you ever get it resolved? If so, how? I’m taking it to Chevy tomorrow and hopefully they can do a better job than Lincoln, but if they can’t either then I would like to know what other things I can do to get it fixed. I would not want to be driving it like this during winter.
Pick-up trucks have done this forever. Mainly on rural gravel roads. We call it washboard roads and is the sign of a poor grader operator.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
    • Rockauto bud. I pass local stores for parts.   Findya something online.
