On 2/23/2020 at 11:41 AM, truckguy82 said:
You are wrong about the lever effect.
Think about bicycle disc brakes vs Traditional cantilever brakes. The disc brakes are all the way center and work even better
If I am wrong about the lever effect we should prbably throw out 50% of all mechanical engineering ever done... and your won't need breaker bars to lossen stuck bolts anymore... that little 4" ratchet handle they sell at Murry's will be fine.
They work better because the hydraulic system produces much higher force of the pads on the rotor than the rim brakes... there are material differences as well.
On 2/22/2020 at 4:42 PM, truckmann said:
Yes. Direct replacement with the caveat of either wheel spacers or some grinding on the calipers for the OEM wheels to fit. So far I'm really happy I did it.
I have a 19 Suburban... Has the same brakes as the pre '19 trucks. Looks like TONS of wheel clearance and my 18" wheels look just like the 18" wheels on 19/20 trucks... Wonder if I will have no issues cause the wheels are the same Truck -> Suburban
The most important thing is not to get them really hot when they are new.
Can you add a little detail about why this is, or the effect of them getting hit when new or not?
Not trying to disagree or anything, I just find stuff like this interesting and would like to know more.
Sent from my SM-N950U using Tapatalk
So there is grinding needed even with the OEM 20" All terrain wheels?
do the 19+ calipers bolt right onto the current brackets and spindles or do the brackets need to be changed as well? Are the original brake lines reused or are those new as well?
This type of caliper won't use a bracket, it will mount directly to the spindle, which seems to be a direct fit, you just need to shim the caliper so that it sits centered on the rotor.
I'm not sure if the stock brake lines will work or not, but it would be a perfect time to upgrade to a set of stainless lines anyway.
It would be a guess but I would assume some grinding on the outer hump of the caliper or a spacer will be needed with most OEM wheels before 2019. The new calipers bolt right to the existing spindles. The existing hoses can be used, but I chose to upgrade to SS braided.
running anything larger than 18" rims on these trucks will def inhibit braking distance, i doubt 18's fit this kit...
would be interesting if someone offered a Hydroboost conversion for the 1500 trucks to get rid of the extraineous vacuum pump system.
18" will fit as far as being big enough diameter to clear the caliper. The 19/20's still have an 18" wheel option.
Hydroboost is awesome. I did that conversion on my 2003 along with the bigger brakes from the 14-18 trucks. Honestly though I don't think I would bother with it on my 14 with how it feels now after upgrading to the 19+ front brakes. I have considered ditching the vacuum pump if there was a good place to tap into the engine vacuum. I have V4 mode tuned out so I think the engine vacuum would be sufficient from what I've read.
Just tap into the pcv line on the side of the intake, easy place to tap into then just run a vented catch can out of the valley.
I'll have to look into it closer. I have a Mighty Mouse catch can on it now.
6 minutes ago, lovelessjl said:
I've seen that one. The issue for me is still being able to use the catch can since it uses those ports.
You could find a breather filter and put that in place of the return line, or switch to a vented catch can like the moroso version. I'd be curious how much vacuum that line holds while connected to the pcv system still.
Lol, ok
the lever effect exists, but it’s irrelevant. There is no net gain or loss of energy by using a larger disc and placing the pad on the outside. If you place a brake pad closer to the interior, you have to clamp harder, but that’s offset by the lack of rotational speed. Considering the clamping force is just a number you can pick out of a hat with an automotive braking system, it means there is no additional stopping power with larger brakes. Thus, it means the only point to having large rotors is heat absorption and dissipation. If you have to convert X joules of energy into heat and to be absorbed and dissipated by a chunk of metal, a big chunk of metal can do that more effectively.
In regards to bike hydraulics is just a means of energy transfer. When you pull the brake lever on the bike, you’re not going to suddenly get more clamping force because hydraulics = magic.
The only reason disc brakes works on a bike is because bike rims constantly bend a little bit and create a wobble. This means your brake pads need to be further away and need to travel more. With the disc brakes, they are going to stay true, which means you can reduce the amount of travel the pad has, which in turn allows you much greater mechanical advantage. When you pull the brake leaver, you pull it maybe 2 inches. 2 inches of hand travel moving the brake pad 3mm, is a whole lot more mechanical advantage than moving the pad 25mm you need for traditional brakes. You could get the same effect with hydraulics or mechanic advantage, it doesn’t matter. The hydraulic method is just a simpler way to transfer large amounts of energy and creates lighter components.
I mean, did you never wonder why every vehicle on the road has the braking power to lock up the brakes no problem, but for some reason sports cars have bigger brakes? Why the hell would they have bigger brakes if a honda civics brakes could easily lock up the tires.
heat dissipation is the only reason, not mechanical advantage
Edited by truckguy82
  • Thanks 1
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
