Passed a car - Check engine blinked 12 times?????
I passed a car this morning, (went around) so I gunned it while I had the chance. Afterward I looked down and saw engine light flashing, scared the crap out of me but before I could do anything it stopped. Any ideas?
Thanks!
Bob
Have you tried to pull any codes?  Most auto parts stores will pull the stored codes for free.  If it was a runtime code, then it may not show anything; but, it's where I'd start.
Oil level to the top? If too low, on a steep grade, etc. high revs could have sucked so much oil from the sump and pumped to the valve covers, especially if a partial blockage on the return lines,  it temporarily triggered the low oil level sensor.
Oil level fine and clean. I’m at work but will check to see if any codes thrown when I get home. It’s just weird AND scary that it was so few flashes. I’ll let y’all know if there’s any codes. Thanks
I did get a tank of crappy gas a few days ago. First time I've seen this so scared me a little. Thanks Guys!
Check engine light flashing indicates a misfire.
Mine did it at random a couple of months ago, it had a code stored in the computer even though the light went off. Code was for number 5 cylinder. Pulled the plug and it had carbon tracing down the side of the plug. Funny thing is it was a brand new NGK plug. So I replaced it and went ahead and put on new wires at the same time.
Actually, a flashing CEL is defined to mean there is a current emissions related problem actively occurring, of which the engine misfiring would cause it to happen, but it's not the sole thing that can make it happen.  You need to get the codes, and then figure out why it's happening.
Been a tech for 20+ years, never in my career seen anything other than a misfire cause a blinking CEL. Have data streamed many cars with misfire issues and emissions issues. Only ever seen a misfire cause the blinking CEL.
Have caught many emissions issues as they occurred, never seen one cause the light to blink.
To the best of my memory the definition of the blinking light is that emissions damage is occurring.
When you have a misfire, engine damage and catalytic converter damage are occurring so I think that's what you were getting at.
I've seen many catalytic converters get fried due to a misfire. Seen a few engines shit a cylinder due to misfire, but not many.
I checked the code this weekend, it was a CO307. Number 7 misfire, only one code. This is the one and only time this has done this so I hope it was just this crappy tank of gas.
Possible, but probably not. I'm a tech and I've seen bad gas cause an issue about 5 times in my 22 year career.
How do you think I should proceed. Do you think it's a bad plug, coil or injector or a combo? Call the dealer and schedule I've got 59k so not sure if drivetrain or my extended warranty will cover the charges. I forgot to add, when I punched it last night it did it again, it happens when the rpms are at about 5k never any other time and it feels like a short lag when I hit it.
Thanks for the info
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
