20 hours ago, BB&Chiveon said:
not checking DEF level is like not checking fuel gauge when picking up new at dealer. Its your fault. CEL has stayed off since fix at dealer last thursday. P20EE fix finally has worked.
Might be true on 2020's, if the 'gauge' is accurate -- I don't have a '20, but it sounds like there are issues with it.
2011 there was no def gauge at all -- just the miles remaining warnings.
2012 - 2019 have a def level indicator.  Won't tell you if it's full -- only gives a %  indication if it thinks their is less than 30%.  Above 30 it just says 'OK'.  Which of course is useless for 'checking to see if full'.
Ya, I know, it's a 2020 thread.
Edited by redwngr
  • Replies 44
Top Posters In This Topic
What was the fix for this problem. I’ve been to dealer 3 times and they said GM told them the fuel pump module is bad. I doubt this is the problem
On 1/20/2020 at 9:23 PM, Fl cowboy said:
I have a 2018 idling around today got a p026d code can anyone give me advice
Truck thinks it has a faulty DEF sensor.
I'd guess they will install a new one.
Let us know.
I'd still take it in and have the code scanned and documented.
I have a 2020 Sierra with 400 miles and the check engine light on.  I see others have had this issue.  Has it been resolved for most, or something I need to get used to.
Not something to get used to.
At 400 miles, get it to a dealer and make use of the warranty you paid for.
There are 100's (or 1000's) of things that could be the cause for the light.
Typically, much easier to find with some service training and with use of a diagnostic computer to help track it down.
You can hit the OnStar button, and they will give you the error codes / DTC's if you are curious...
Check engine came on my truck today at 15k. I went to auto-zone to get check and it wasn’t showing anything (maybe truck is too new for their device) and thn I called OnStar (P20EE) showed.
I’ll be going to dealer next week.
Edited by TrailDemon
I got the P20EE code at 800 miles after pulling a trailer for an extended period of time. I reset the light and it has not come back on in over 7000 miles.
Sent from my SM-G981U using Tapatalk
I hate to see that light so I reset as well. Already drove 100+ miles and still clear dash
  • 6 months later...
5,777 miles.
2020 Chevy Silverado 2500.
When put in drive, lags down, truck shuts down. Rear end locked up when trying to put on flatbed tow truck. Same email as others : engine and transmission issue detected.
being towed to the dealership as I type this.
12/28/20
17:00
    250.6k
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 246 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
