20 hours ago, BB&Chiveon said:
not checking DEF level is like not checking fuel gauge when picking up new at dealer. Its your fault. CEL has stayed off since fix at dealer last thursday. P20EE fix finally has worked.
Might be true on 2020's, if the 'gauge' is accurate -- I don't have a '20, but it sounds like there are issues with it.
2011 there was no def gauge at all -- just the miles remaining warnings.
2012 - 2019 have a def level indicator.  Won't tell you if it's full -- only gives a %  indication if it thinks their is less than 30%.  Above 30 it just says 'OK'.  Which of course is useless for 'checking to see if full'.
Ya, I know, it's a 2020 thread.
Edited by redwngr
  • Replies 44
Top Posters In This Topic
What was the fix for this problem. I’ve been to dealer 3 times and they said GM told them the fuel pump module is bad. I doubt this is the problem
On 1/20/2020 at 9:23 PM, Fl cowboy said:
I have a 2018 idling around today got a p026d code can anyone give me advice
Truck thinks it has a faulty DEF sensor.
I'd guess they will install a new one.
Let us know.
I'd still take it in and have the code scanned and documented.
I have a 2020 Sierra with 400 miles and the check engine light on.  I see others have had this issue.  Has it been resolved for most, or something I need to get used to.
Not something to get used to.
At 400 miles, get it to a dealer and make use of the warranty you paid for.
There are 100's (or 1000's) of things that could be the cause for the light.
Typically, much easier to find with some service training and with use of a diagnostic computer to help track it down.
You can hit the OnStar button, and they will give you the error codes / DTC's if you are curious...
Check engine came on my truck today at 15k. I went to auto-zone to get check and it wasn’t showing anything (maybe truck is too new for their device) and thn I called OnStar (P20EE) showed.
I’ll be going to dealer next week.
Edited by TrailDemon
I got the P20EE code at 800 miles after pulling a trailer for an extended period of time. I reset the light and it has not come back on in over 7000 miles.
Sent from my SM-G981U using Tapatalk
I hate to see that light so I reset as well. Already drove 100+ miles and still clear dash
  • 6 months later...
5,777 miles.
2020 Chevy Silverado 2500.
When put in drive, lags down, truck shuts down. Rear end locked up when trying to put on flatbed tow truck. Same email as others : engine and transmission issue detected.
being towed to the dealership as I type this.
12/28/20
17:00
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
