Weird water problem
Update, I have narrowed it down to the door area. I washed my truck yesterday, figured if I was going to be pouring water over it I might as well, and the only place that got wet was under those wiring harness brackets that are under the rocker panel covers. I just replaced the main door seal so I don't see how it got past it. I guess I'll try a thin bead of silicone under the door seal and see if that helps.
Well I found the leak, it was the third taillight. I feel kinda stupid for not checking that sooner I guess it goes to show you investigate thoroughly before you start buying parts. 150 for a door seal compared to 4 dollars for a tube of silicone
