Going 12 wide from 10 wide wheels
gapple12
So, I recently switched from a 10 wide to a 12 wide wheel on a Nitto Ridge 35 tire, same tires on previous wheels. Tires only have about 10k on them. I also had them rotate the tires for the first time. When I drove the truck home, I was shocked how bad it rode. I had 12 wides on my last truck and it was nothing like this. Checked air pressure and it was good at about 37. Seems like the tires are riding real bumpy now and I feel every little crack and bump in the road plus a slight vibration anything over 40mph. Doing 70 this morning on my way to work was just awful rough. Is it possible they rotated the tires wrong ? Doesn't seem like there out o balance from the rough feel.
What is the section width of your tires? If you are stretching them to fit the 12's, then that could be an issue. It more than likely has something to do with the new wheels since everything was fine before, whether they are too wide for your tires, or one is out of round.
The Tires are 35x12.50R20 on a Gear Alloy big block 20x12. I called the tire shop and he said he did a X pattern on the rotation and I might be feeling the tire adjusting. I thought you only rotated off road tires front to back, not crisscross ?
Generally if the tire is not direction dependent, you want to rotate the tires through all 4 positions after 3 changes. See the images in this link. Rearward cross is most often used for 4x4 trucks.
Front-to-back is only for tires with a specific tread pattern that is direction dependent.
https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=43
So, if the rough ride is caused by the 12" wide wheel, would going to a wider tire fix that? For instance, I am running a 12.5 wide tire, what if i went to a 13.5 wide tire ?
I can't say for sure. The reason I asked the width of your tire is I've seen many people stretch narrow tires onto very wide wheels and they ride like poopoo. Usually for a x12.50 tire, they recommend a wheel width of about 8-9/maybe 10 inches at most, but plenty of people run 12 inch wide wheels with that tire size. It's tough to say what exactly is causing your issue from across computer screens, but you might want to have them verify balance if it's that bad. But generally, yes, when you stretch a sidewall out a bit to fit wider wheels, the ride tends to stiffen up a bit.
Are the wheels hub centric or lug centric?
How are they balanced? With a dynamic balance or a static balance?
Were they road forced balanced when you switched rims?
Did you ever figure it out. Mine is doing the same after installing 35x12.50x18. Took it to 2 different shops to have them balanced again. Going to try the balance beads in the morning
With mine, the ride got worse going to the 12 wide wheel. Every shop I have called said that is the case since i am stretching the tire. With these bigger tires and wheels, the factory shocks and struts cant handle them well so you feel everything. I am going to swap out my factory struts to a Fox coil over or Rough Country Vertex system and see how much better it is.
6 minutes ago, gapple12 said:
With mine, the ride got worse going to the 12 wide tire. Every shop I have called said that is the case since i am stretching the tire. With these bigger tires and wheels, the factory shocks and struts cant handle them well so you feel everything. I am going to swap out my factory struts to a Fox coil over or Rough Country Vertex system and see how much better it is.
Well that sucks to hear. If this balancing beads don’t work ( which I’m pretty sure they won’t). I’m just going to throw the factory tires back on and sell these tires
What brand/type tires you running ?
Got them off amazon. They are called  Thunderer R408 All- Season Radial Tire-35/12.50R18 127Q
OK, well that is an off-brand tire. In my experience, sometimes a generic tire will vibrate and have a hard time balancing. They dont get the best QC before they ship out and you might have one that is bad. I have had some black bear tires that would not run smooth no matter what. Also had some atturo tires with the same issue.
Yea. That’s what I’m thinking. I went cheaper tire and now I’m paying for it. (Although 180 dollars a tire, isn’t cheap lol).
Should of went name brand. Kicking myself for it
In your experience. Should I try a different brand at 35x12.50x18.
Or  or just go a little smaller like at a 265/75/18 Which I think is like 33/10/18
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
