On 6/8/2020 at 9:29 AM, Tony Ankar said:
2020 GMC Sierra 1500
Sounds like I have the same issue as some of you.  Driver side air conditioning is not cold.  Took it in with 1200 miles - refrigerant was low.  Service re-charged refrigerant and put in green dye.  Same issue came back 3 weeks later.  Refrigerant was 50%.  Clearly a leak but they cannot detect the leak.  They are saying they may have to replace/repair the evaporator (which is a pretty invasive fix).  Possibly the condenser.
Has anyone had this issue resolved?  What was the solution in your case?
Update:
3,500 miles on my 2020 Sierra 1500...  No A/C on driver side (blows hot air out), then all A/C goes.  Dyed, pressure tested, and can't find a leak.  Last "repair" attempt (i.e. recharge refrigerant) lasted two weeks.  After 3 or 4 visits to GMC service, finally got them to order new parts.
Replaced the condenser.  No leaks found.  Replaced condenser unit anyway.
Took the entire dashboard out to access the evaporator.  *Found leak on evaporator.  Replaced evaporator.
1 week and 500 miles have gone by.  So far, so good.  We'll see..
Edited by Tony Ankar
Mine too was the evaporator.  Well so they say.  Just about 2 days worth of repair.
  • 3 months later...
I'm having the same problem on a 2019 Silverado (bought new). Took it in the first time at about 7,000 miles when driver side was not cooling; coolant was low, no leak could be detected. Dealer recharged and added dye to system. Taking vehicle back today (four months later), as coolant has apparently leaked out again.  Passenger side cooling, driver side not cooling once outside temperature reaches over 80 degrees. Vehicle has now been in the shop again for two days. Service department confirms system is definitely leaking, still unable to detect the leaks location after adding dye a months back. Service rep today said he was going to "contact engineering to see if they aware of any problems," as the Service Department if befuddled by it. I find it hard to believe a Chevy Service Department is not aware of this issue.
Edited by evangmlw
Mispelling
It is either the evap or condenser, these dealers know this and stall trying to use the lets recharge it and put dye in patch fix, if it worked fine before and then all the sudden didn't it is because it is leaking out of either of those parts, sometimes even a bad compressor but those usually will last past warranty before expiring and even the lines feeding it all have had a tendency to leak. This has been an ongoing issue since the 14 model year, same parts, same problems. Gm previous fix of the condenser was to literally stick a 3" x 5" piece of foil tape over the top right corner to try and help dissipate the heat that was causing condensers to fail and leak.
GM literally using duct tape to fix their incompetence, once you are past your 36k the fix is on you!
Edited by BIGDOGx
  • 7 months later...
Hi guys. Yes, they all break down. Especially new models of air conditioners that work for a year and break down. It will be interesting to know how you found a solution to this problem.
Just wanted to post here that I battled with No Air Conditioning for a couple of months (2020 Silverado).  The first 2 times they did a pressure check and dye check and couldn't find anything.  They only refilled refrigerant and sent me on my way.  They stated that they have had no problems on the newer Silverado model so they baffled.  I am pretty sure if the refrigerant is low on a new truck then there is a leak somewhere.  Finally on the 3rd trip to the dealer they decide to "tear everything apart" to find the issue. They found that the evaporator core was leaking and replaced it.  This required them to pull the entire dash out to access and replace.  This has fixed the issue for now, but they created a a few new problems that they are going to have to fix this week.  They messed up the SD card reader and USB ports in the center console and the dash looks like a five year old tried to put it back together.   I hate that a vehicle that cost as much as this has to be torn apart to fix something as simple as air conditioning.
  • 2 months later...
On 8/28/2019 at 9:06 PM, deminimis said:
'19 3500 L5P (black/black)  Over 100 today and AC isn't working.  My guess is the climate control computer got really hot and that caused it.  Was in direct sun for about 3 hours.  After leaving in shade at home, it's now working.  Pretty lame.  Anyone have this issue? Is there a fix?  Hate to waste a day at the dealer just to be told is a-okay.  (Compressor clutch wasn't engaging, by the way.  Ice cold now that it's working again). Thanks.
My 2019 Silverado AC rarely does not cool so dealer cannot diagnose because it works there. Yesterday it was 89 degrees and worked fine. We were at church for 1.5 hours and headed for a restaurant and was working fine. Outside temp shown on dash was 89. About 10 miles down the road it started blowing hot air. I looked on dash and outside temp showed 32 degrees. I’m guessing the computer wasn’t going to blow cold air. Finally temp increases on dash and cold ac again.
After a couple of trips to the dealer, they found a leak and fixed it.  No issue since.  Well, no issue with the AC since.  Brakes went to crap, but that's for another thread.
I have a 2021 3500 Denali Dually.  At 2,000 miles, the AC failed pulling my 5th wheel toy hauler from AZ to NY.  Had to go half way across the country with no AC.  Sucked in a new truck.  Once in NY, they said a "module" was bad, replaced it in about an hour, and presto.  But, on my way back from NY, it went out again in Texas.  Both times, it went out, came back on, off and on until complete fail and blowing out hot, humid air.  Once in AZ, took it in, and, they can't see a problem.  It fixed itself.  But now, it poops out, and recovers, off and on.  The dealership said bring it in when it acts up . . . but, of course, the truck knows when it's in the shop and is gas-lighting me.  Anyone else going thru this silliness in you new and very expensive truck?
  • 11 months later...
have a 2021 chevy 3500 6.6 diesel. ac not cooling at times as well. we just replaced the fan clutch because it was weak causing insufficient airflow thru condenser. truck only have 35k on it. dealer could not get to truck till december. ac is now colder than before we replaced the fan clutch but driver states ac cuts out goes hot then ac comes back cold again. i have seen data stating low voltage to ac compressor clutch relay. truck is not modified. only have raptor lights in grille and hooked up to passenger side headlight parking light circuit. anyone have any ideas
This is certainly not what we like to hear, MALFUNCTION JUNCTION AUTOMOTIVE.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2021 Chevy 3500. To do so, please send an email to [email protected] with ATTN: MALFUNCTION JUNCTION AUTOMOTIVE/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
I am going through this myself on my 2021 Sierra 1500. They have replaced the compressor, the evaporator hose, the sensor on the driver side, and are now in the process of replacing the evaporator. Also basically unable to find a significant leak, but it continually runs out of refrigerant. this is the 5th time I have brought it in for A/C issues in the 18 months I have owned it... VERY frustrating!
  • 10 months later...
I’m having somewhat same issues in my 2021 Chevy custom 6.6 gas, was blowing cold this morning and went in to watch a movie for 2 and half hours at a theater, temperature in truck was at 111 and turn truck on and air and no air flow at all. Trying to figure out the issue, fuse look good. But when you turn switch on there’s no air flow from any vents.
    • I wonder how much carbon is on all those high mileage valves?
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
