Exhaust tip removal DIY
PabloK
How much are you guys getting charged to powder coat the tips?  I was going to buy a powder coated set from eBay, but figured it’ll be less expensive to find my own local powder coater -
I bought mine off eBay from the seller on here for $150. They’re $200 now. I’ll be cerakoting my old set to sell probably and try to break even.
  • Replies 104
So what's the verdict guys, do you need to powder coating or is plastidip holding up fine since it's just tips? I really dread taking those off... haha.
and do you think white would look good on a white TB?
OP stated before that his plastidip bubbled up and peeled off. You’ll need something more permanent. And no on white
I wouldn’t do white especially with the black residue that comes out of the tailpipe. Removing them really isn’t bad. Even my 10 yr old son helped quite a bit
Ryan B.
I have a White AT4 , thinking Matte black tips . Thoughts ?
The matte black are nice
Ryan B.
Ryan B.
You are not kidding , that looks great . I went ahead and ordered matte from Official Powder Coating .
  • 3 weeks later...
Powder coating starting to fail after 21,000 miles
Could have been a bad PC job too... who knows
PabloK-
If this was one of ours, please email me at [email protected] and I'll arrange to have this exchanged for a new set. This should not have happened.
PabloK-
I don’t think it is. One of the earlier post says he took his off and planned to go to a local powder coater.
I have a Red Hot Trail Boss.  I was thinking of making my exhaust tips red.  Just not sure if it would look too overdone.  Anyone seen anything like this?  Pictures?
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 472 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
