Exhaust tip removal DIY
PabloK
26 minutes ago, Dbrace said:
Just took mine off in about 10 minutes without removing the bumper step. The key was using an air ratchet with 10mm socket. Has anyone sprayed there own with high temp gloss black paint? Im going to sandblast the chrome off first. Then I’m going to use Rustoleum high temp primer and then use Rustoleum high temp gloss black spray paint.
Pictures and steps?
  • Replies 104
On 3/30/2020 at 2:43 PM, derek_05_07 said:
Pictures and steps?
Hard to get pictures of the 3 10mm bolts on top of the exhaust tips. I had to fish the air ratchet into the bumper from the back side to loosen two of the three bolts... but here’s how they came out. Sandblasted, 3 coats of high temp primer and 3 coats of high temp gloss black
This is with them reinstalled...I think it came out really good and only cost me $10.
Thanks to this thread I was able to do mine the other day, except I used cerakote graphite black , here is my my 2020CTB
  • 3 weeks later...
On 9/23/2019 at 10:35 PM, PabloK said:
This is passenger side.
This is step 1.
Mods can we unlock my first post so i can update it with better pics?
c285fc0afd43d314547facd4f35fba7b.plist
I gotta do this but don't understand the part about "with trim tool" to remove the step bumper. I don't have a trim tool. How exactly is it used and can I use some other tool?
If I remember correctly, you use the trim tool to push down (possibly up) on the three tabs to release it from the footwell. But I think it’s down that I did.
10 minutes ago, wahoowad said:
Does it require the special trim tool? If not how does one get these tabs free?
Nothing special, just go onto Amazon and look up trim removal kit, they're under $10
You can use a very small flathead screwdriver too
How much are you guys getting charged to powder coat the tips?  I was going to buy a powder coated set from eBay, but figured it’ll be less expensive to find my own local powder coater -
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
