Wheel alignment
To the more mechanically inclined, I need you help. I recently bought a brand new 2019 2500 Duramax (I know wrong forum but its the same generation and there's a lot more people in this subforum) and upon driving it home from the dealer (300 miles from my house) I noticed the alignment was off with the truck pulling to the right and the GMC logo on the steering wheel being cocked 10 degrees to the right while driving straight. Was heading right out of town for a trip so I didn't get the truck in til a week after purchase and the new dealer claimed to align it. Fast forward a couple days and I finally get on the highway and notice the alignment is still off. So I go back to the dealer that aligned it and after a few hours they admit that they can't finish an alingment because their machine isn't big enough for a 2500 and they don't ever work on the larger trucks. So I schedule with a chevy dealer and take it in on Monday. After 3 hours they blame their machine for failing and they need to keep it over night so the alignment machine can reset. Mid day yesterday I get a call that my truck is all good to go. Driving home I definitely felt an improvement but today on the freeway it seemed just as bad as ever with the wheel being cocked to the right (not as much pull to the left tho). Think I am going to take it back in to a third dealer but after 4 alignment trips in 3 weeks Im almost ready to threaten talking to a lemon lawyer. I don't want to as I love the truck otherwise but it seems GM is jacking me off (thankfully they haven't suggested that I pay for these alignments as the truck has 1600 miles on it and 1100 when I first brought it in). My question is do you think they just suck at aligment or is their an underlying issue that could be causing the truck to quickly fall out of alignment? Appreciate any and all insight. Thanks.
Underlining issue is they don't know what they are doing. Make sure the steering rack is at Zero. Not just eye ball the steering wheel and call it good. Then known there is a crown in roads and you may see it off a little but when I say little I say little so little its noticable. If you need there are electrical programs that plug in and diagnose the steering tacks. I am not saying buy one I am saying find a shop that has it and knows.
I had mine at alignment shop 2 times to get right. I had.to gonback and show him what to do.
Also ask for a before and after print out of the alignment alone with the trucks alignment specs. It keeps people honest and educates you. That said you will find that there are alignments and then there are ALIGNMENTS. When you see the printouts you will understand what I mean. It isn't the truck sir. It's the guy twisting the wrenches. These IS someone in your area with a stunning public record of service. Find him/her.
As always spot on GB. I had a semi truck shop that also did frame straightening. They did my road track cars. Perfect every time. Best there was in area. With truck on 24" I used Belltire. And got print out. They fought me saying truck was lowered so the spec are good for that. I refused and demanded stock parameter specs. 3rd time they got it and it is perfect.
I have has issues at dealers but I have never had a problem when I take my truck to a 4x4 shop. The 3 I have used have always done alignments correct the first time. Might want to look into a place like that.
Sent from my SM-G935V using Tapatalk
Thank you. I respect your insight a lot from all of your posts on this forum.
Thanks for the advice. Conveniently both the dealers I've been to have been having printer issues with the printers connected to their alignment racks. When I go to the third dealer on Monday I'm going to say tell them to take a picture of it or write down the specs.
Yeah I've been reluctant to do that but probably will if this third dealer doesn't work out on Monday. It's just its a brand new truck with 1800 miles on it and GM should be paying for it to be within spec.
The front end isn't even broke in yet. I wait til the 1st oil change at 5K miles and do a 2nd check at 7,500 or 8K miles. Then I know it is good. But if it is that noticeable then Yes I would agree it is the wrench turner... especially after 2 or 3 realighnents.
Example:
This is my current alignment. Starting with the camber. Left front needs to be a quarter degree more positive than the right front. As I prefer a hair negative camber this means the left front is less negative to be more positive. :) If you look at the spec range for example of the front left it is +0.7 to -0.9 which is .02 more positive that the right fronts +.05 to -1.1. It is dead center of the spec.
Castor ditto. 0.25 more positive caster left side than right. The machine reads only full tenths so 0.2/0.3 is good and again dead center spec.
The quarter positive camber and castor RF is for the roads crown. Keeps it from climbing the crown and putting you into the on coming lane.
Toe is positive and dead center spec.
While you can't see it in this sheet the steer ahead and thrust angles are zero. On a flat piece of straight road I can take my hands off the wheel for over a mile and stay in my lane.
Some shops are good if each spec is in spec, Example of such an alignment might be:
Camber RF +.06 LF -1.0
Castor RF 1.5 LF 3.0 (cross castor would be near center spec even though this is really messed up)
Toe RF 0.0 LF -0.5
He isn't lying when he says it's in spec. It just isn't close to right.
This is how it left the factory. About as messed up as it can get. Both camber and castor are more positive right side, backward. Castor flat out of spec. Toe, steer ahead and look at that trust angle. (dog tracking). Amazingly this went down the road pretty straight. Why? Look at that castor!!!.
Forgot to mention. I had castor set to the lower half. This helps calm the jar when you hit an expansion joint or a rail road track. Still centers itself after a turn. Think that's it. Sorry to be so scatter brained. YIKES!! :)
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
