royalkangaroo Posted October 2, 2019 Posted October 2, 2019 Lately, my truck doesn’t seem to turn over cleanly. Almost like the starter isn’t engaging solidly. Happens like 1 out of 5 starts. 2015 Sierra with 54k miles. Any ideas?
Snowcamo Posted October 2, 2019 Posted October 2, 2019 Time for a new starter. I took mine a part and cleaned, lubed and reassembled more then i can count. Its the solenoid not kicking out the plunger which is connected to an arm that engages the starting gear. Sent from my LG-G710 using Tapatalk
Jmiller11331 Posted October 2, 2019 Posted October 2, 2019 Lately, my truck doesn’t seem to turn over cleanly. Almost like the starter isn’t engaging solidly. Happens like 1 out of 5 starts. 2015 Sierra with 54k miles. Any ideas?Mine does the same thing 32k milesSent from my iPhone using Tapatalk
Snowcamo Posted October 2, 2019 Posted October 2, 2019 I'll be honest per my financial advisor(wife) i got one from a 2015 that i just put on like an hour ago and its the revised/updated version. The parts do not interchange so no go there. The updated version sounds and is way more powerfull when turning over the engine. The first version has/had a recall due to it not engaging. I tried to contact GM but they say I have zero open recalls. Sent from my LG-G710 using Tapatalk
Snowcamo Posted October 2, 2019 Posted October 2, 2019 The first pic is the updated version the original one had the ignition wire built into Sent from my LG-G710 using Tapatalk
royalkangaroo Posted October 2, 2019 Author Posted October 2, 2019 9 hours ago, Snowcamo said: I'll be honest per my financial advisor(wife) i got one from a 2015 that i just put on like an hour ago and its the revised/updated version. The parts do not interchange so no go there. The updated version sounds and is way more powerfull when turning over the engine. The first version has/had a recall due to it not engaging. I tried to contact GM but they say I have zero open recalls. Sent from my LG-G710 using Tapatalk Where’d you get your replacement?
Snowcamo Posted October 2, 2019 Posted October 2, 2019 Where’d you get your replacement?A local salvage yard. Try car-part.com its a local to the user list of parts from all local salvage yards that also list there prices. Sent from my LG-G710 using Tapatalk
BigBadSierra Posted October 2, 2019 Posted October 2, 2019 If your on your original battery I would get that tested before I started swapping out parts. The starter is the single highest power draw on a battery. If the battery is starting to go that could be your issue as well.. Just getting a simple load test done will tell you.
diyer2 Posted October 2, 2019 Posted October 2, 2019 I would think the up dated version would be available new from auto parts suppliers. For sure from GM.
diyer2 Posted October 2, 2019 Posted October 2, 2019 10 minutes ago, BigBadSierra said: If your on your original battery I would get that tested before I started swapping out parts. The starter is the single highest power draw on a battery. If the battery is starting to go that could be your issue as well.. Just getting a simple load test done will tell you. Agree
Snowcamo Posted October 2, 2019 Posted October 2, 2019 If your on your original battery I would get that tested before I started swapping out parts. The starter is the single highest power draw on a battery. If the battery is starting to go that could be your issue as well.. Just getting a simple load test done will tell you. Its a good idea but will not solve the problem with the first gen starter. My batt is new. The battery condition has nothing to do with the solenoid not engaging the starter gear. The starter gear motor spins freely without any issue. It's just the solenoid won't engage the gear. This is really noticeable when the engine is hot after a travel.Sent from my LG-G710 using Tapatalk
Snowcamo Posted October 2, 2019 Posted October 2, 2019 I would think the up dated version would be available new from auto parts suppliers. For sure from GM. [emoji4]It is but for me ever penny counts. Im saving to open my own HVAC business.Sent from my LG-G710 using Tapatalk
diyer2 Posted October 2, 2019 Posted October 2, 2019 7 minutes ago, Snowcamo said: It is but for me ever penny counts. Im saving to open my own HVAC business. Sent from my LG-G710 using Tapatalk OK But a dependable truck would benefit a business IMO.
Snowcamo Posted October 2, 2019 Posted October 2, 2019 Its dependable... 50 bucks too. Just because im not giving gm one dime or paying 160+ doesnt mean its not dependable. It came from a 34k truck. No worries here there or where. Its all good. [emoji2][emoji106]Sent from my LG-G710 using Tapatalk
