New guy, need help my friends!
That's no favor from them. Any service department could have offered you that deal. It used to be called "Goodwill" and no deductible applied until every claim was done that way and people abused it. Now GM dealerships have a calculator they can run the repair through and determine the deductible to the customer when slightly out of warranty. The longer out/higher mileage the higher the more the customer participation is $$. Those parts are all swaps through TechniCar so the General will only pay around $400 bucks plus warranty labor time. I used to do this for all good customers to gain their maintenance and gravy work. Id make the dealer pay the deductible. Good Luck!
That may all be true, but I’d pay the $125 and be happy.  They didn’t need to do anything.  They stepped up even if it didn’t cost them much.  Pay the funds and call it done.
Don’t get me wrong if you feel like you’re getting a deal then it worked and you “won”. I loved people like you. I made my living for many many years that way. [emoji1303]
4 hours ago, Denali34 said:
Don’t get me wrong if you feel like you’re getting a deal then it worked and you “won”. I loved people like you. I made my living for many many years that way. emoji1303.png
Okay, but what effort is it going to take for the OP to get out of paying $125?  I recognize that he may be able to really win and pay nothing, but at what cost?  I think the “people like you” are people that don’t want to spend any more time on an aggravating situation.  Plus, there is no guarantee that he’ll win.  I think you made your living playing the odds.  All’s fair.  That still gets him out of paying the full boat.  It’s even better than what you think GM will have to pay.
I’m still with taking the hit of $125 and getting on with his life unless the $125 is truly a financial hardship, which could always be possible.
Like I said before. If he feels he won then all is great! Everybody won in that situation. What’s a $125 in the grand scheme of it? An oil change or a couple tanks of fuel? [emoji6] Great deal!
I honestly don’t mind paying the $125. I was offered an extended warranty and turned it down. While this, and all dealerships should offer a minimum 30 day on any used purchase, they don’t and I knew it. The service manager is in constant contact me and I feel like they want my business. There was even a small dent in the rear door when I bought it, manager saw it today and had there dent guy who only comes once a week go ahead and pull it for me, no charge. I know it’s all a game, I know if I push I might get it all for free but it’s just not worth it to me when I honestly feel like they are trying to help me.
These repairs are costing me less than a pizza dinner for me, my wife and 4 hungry hippo boys.
Well said!   I'm glad they made the right choice to help you but not surprised they made you sweat a little.
Alright folks here’s my update. Got the truck back after 2 weeks. Mirror, radio and dent fixed. Total for me $114. I’m happy, glad to have my new truck back. I could have fought for free repairs but it just wasn’t worth it. Got her back, now I can keep modding.
*America!
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
