On 7/20/2022 at 12:52 PM, Brent D said:
I dont want to steal kodiaks credit for coming up with the idea....but i just got a 3d printer and want to tinker and will try and post a .stl for these when i get a design that works well. Dont want to recreate the wheel but too cheap to pay for what i can maybe make.
**Please buy sets from Kodiak as I will not be making any to sell just for my own personal use. **
Kodiak...On a side note though maybe you could get a few $$ for .stl file alone privately for those who have printers but dont want to take the time to design.
I'll even give you a hand if you need it. What software do you like to use for 3d models?
the critical dimensions that worked for me, the ones for the part that gives a good tight fit on the inside of the square cross member are: width 68mm, height 71mm, corner radius 20mm. on my plugs actually the corners are the primary area of contact (where the fit is the most interference), this keeps them nice and tight but helps to make sure they are removable for periodic cleaning throughout the life of the truck. After all there are other passages for stuff to get inside the frame other than the open ends of the cross members. When capped it should reduce the introduction of debris and salt a huge amount. It's still good to be able to occasionally flush them out just in case.
I just started using tinkercad as it seemed to have the easist  entry into 3d world. I just got done making the round caps that worked for my application (2nd one still printing as we speak). I was getting a variable from the actual tinker cad to the end product of +/- .8mm which you wouldnt think is much but it is when it comes to sizing a hole that 1 isnt truly round, and 2 has some slight surface rust causing imperfections. I took me 3 itterations to come up with it a model that is tight and tough/flexible enough to  be pounded in with a mallet without cracking. Im using PLA+ though for now which is fine as it is not a moving part. Will upgrade to ABS down the road. I used digital calipers to know my large and small diameters and split the difference. My first one was just slightly too large and wouldnt even start to go in, the next one was too loose. This last one was tight but got it to go in . I used 1.73 diameter (didnt have calipers til today for mm) as a reference outter diameter for the plug and that seemed to work just perfect. I will start messing with the rectangles tomorrow.  I will post up the tinker cad files and .stl files for our users to mess with on here. I had fun just messing with it and the DIY. Just wish it didnt take 1.5 hours (twice) to find out it didnt work..lol
.obj file to adjust to whatever micro adjustments you need for your application. I ran mine at 100% infill .3mm height for speed using PLA+. Tool 1.5 hours each.
2019+GMC Caps Round.obj
Kodiak what 3d modeler are you using, cant seem to do radius with tinker cad as it wants to radius every side of object not just what I want.
I use openscad for almost everything. I'm a programmer so the code based modelling is intuitive. Unfortunately I have no experience with tinkercad, heard of it, never used it.
I also do some work in freecad. The radius isn't the easiest thing in open scad either but with the right libraries its easy enough to produce. its pretty simple in Freecad though.
I have a lot of experience in Autocad, but all 2d...so its like starting over...will check out freecad.
I hear ya. You might find Freecad reasonable to learn then. its interface and UI and all are not quite like autocad but you make your 3d designs in one of a few different ways. you can insert primitives and do booleans on them, or you can draw 2D schematics then extrude them into 3D space. then you can pick a face on any surface in that mesh and create a new 2D sketch on that face and extrude or pocket to add geometry or make holes. And you can easily fillet or chamfer edges by selecting a 3D object, a face, or specific edges. 2D cad experience might translate fairly well.
  • 4 weeks later...
On 5/26/2022 at 2:57 PM, kodiakdenali said:
Updated design for additional strength to make sure its removable for maintenance.
Do you have the object file by chance i really would like to print this! Thank you
  • 4 months later...
  • 1 year later...
If anyone is making them for a 2023 or knows where to get a set Im a buyer. It looks like the rear hole is about 1.75" and the rear opening is more squared and measures roughly 2.5x3" Does this sound correct?  Again, if anyone knows where I can get a set, Im a buyer maybe two sets.  Thank you.
One other thing. Has anyone thought of making a groove around the plugs for an o-ring or are they already plenty tight?  Thanks
I still make and sell them, shoot me a message! They do have a space on the back where a gasket or o ring would fit if you could locate one of the right size. I make both the square or round plugs.
  • 4 weeks later...
  • 1 month later...
20 hours ago, BBL_28 said:
How do I contact Kodiakdenali directly to get a set of plugs?
Got your message! Contacting me though direct message right here is a good way to get a hold of me. I’m still making the plugs for anyone who asks for them. shipping costs a couple bucks more than it used to but I still honor the original price in this thread. Anyone looking for them, feel free to message me!
    Gilkey96
    Gilkey96
  • Who's Online   5 Members, 0 Anonymous, 783 Guests (See full list)
    • When I bought my 14 GMC I turned it off with an handheld programmer. With my 16 Odyssey I left it on solely because I didn’t have much money in the vehicle. There’s a device to turn it off that’s a little more involved. The GMC at 72 MPH the deactivation was on very little the deference was 1/2 mile per gallon. The Odyssey is on over half the time at 72 mph.
    • Anyone ever thought about switching the interior door panels from the base model to the Denali style? I’ve seen that you basically have to cut, sand, mold, paint, the window switches together to get the look right. Is that the main reason people don’t bother doing the swap? Seems like the only method that is easy I guess, without having to mess around with wiring and stuff.
    • Replace the fuel pump with an OEM AC-Delco.
    • Hello, first time posting here. I have an 03 Chevy 1500HD with the 6 liter gas engine. The truck ran fine until the fuel pump died on me and had to get it towed. Replaced the fuel pump with a precision pump from O’rileys and changed the fuel filter while I was there. The truck will run and drive now but it wants to idle around 500 rpm when in drive and it tries to stall if you touch the gas. It drives fine though, just doesn’t want to idle. Put a fuel pressure gauge on the rail and only have 50 psi. I guess these trucks should have 55-62 psi to run right. I thought the regulator might be the issue because when I would unplug the vacuum hose it jumped to 56 psi. Replaced the regulator and no change. The only thing I can think of is that I was sold a faulty fuel pump. Any help would be appreciated because I’d rather not have to take the bed off again if I don’t have too. Thank you!
    • I've been wrenching on GM trucks for 17 years. And I need to get something off my chest because it's been weighing on me for a long time. After all that time, all those motors, all those people standing in my bay, I've figured out there are really only two kinds of owners. The ones who already know about this. And the ones who are about to find out the hard way. A guy came into my shop a few weeks back in a 2018 Silverado 5.3. Sharp guy, maybe 35. Knew his truck cold. He'd been on the forums, read the threads, done his homework. He only rolled in so I could double-check a little module he'd already plugged in himself. Wanted a second set of eyes on it. Ten minutes, in and out, drove off happy. Two days later, a completely different story walked through the same door. Older fella this time, in a 2016 Sierra. Gorgeous truck, clearly babied, not a scratch on it. Wedding ring. Looked like a guy who took care of his stuff. He was in because his engine had started knocking on the way to work. And by the time I got the valve cover off, I already knew it was too late. Lifter collapsed. Cylinder 5. Camshaft chewed up. The whole top end shot. Same kind of truck. Same motor. Same roads, probably the same dealer. The only thing separating those two men was information. I've been at this since 2008, and I've worked on everything GM puts out. Silverados. Sierras. Tahoes. Yukons. Suburbans. Escalades. The 5.3 and the 6.2. Doesn't matter which badge is on the tailgate. They all carry the same problem. So here's the information one of those guys had and the other one didn't. It's called Active Fuel Management. AFM. GM started building it into their V6s and V8s back in 2007 to squeeze out a little better mileage on the highway. Maybe a mile or two a gallon. All to hit government fuel economy numbers. The way it works, the motor quietly shuts down half its cylinders when you're just cruising along. And the little lifters that pull that off have a tiny pin inside them that's constantly clicking in and out. Lock, unlock, lock, unlock. Hundreds of times a drive. Thousands of times a week. Eventually one of those pins wears through. The lifter drops. And it starts grinding the camshaft down like a chisel on butter. And what nobody tells you is that the shudder you feel around 40 or 50 mph? That's the system cycling. Every single time. Here's what really gets me. The pre-2007 trucks, the ones without AFM, they're bulletproof. I've got customers still daily driving them with 260,000 miles on the odometer. Not a problem in the world. GM took a perfectly good motor that would have lasted a lifetime and bolted this system onto it. And it is wrecking engines that should have run forever. The guys who hang around the forums already know all of this. So do the techs. They handled this years ago. They didn't sit around waiting for the dealership to mail them a warning letter, because that letter is never coming. It's the guys who figured somebody would've told them who end up on my lift. And I want to be clear, because this part matters. Maintenance has nothing to do with it. I've torn down motors with barely 30,000 miles on the clock. I pulled apart a Tahoe last summer with 24,000 on it. Practically a brand new truck. Owner had it less than a year. Spotless oil. Best synthetic money can buy, changed early every time. Made no difference. I've seen guys with full dealer records, every interval stamped. Made no difference. The oil changes were never the problem. The pin was. And no amount of babying that truck stops that pin from cycling every single time you drive. That's the part that eats at me. These are good motors. Take the AFM out of the equation and a 5.3 or a 6.2 will run 300,000 miles and never blink. So a few years ago I started telling every single owner who comes through my doors the exact same thing the smart guys already knew. Get yourself a FullForce disabler. It plugs right into the port under your dash. Couple of seconds and you're done. It just tells the computer to leave every cylinder running, full time. No more cycling. No more beating those lifters back and forth every time you turn the key. It doesn't reprogram anything. Doesn't touch your tune. And unplug it before a dealer visit and there's absolutely zero trace it was ever installed. I've had customers come back at 40,000, 60,000, 80,000 miles after I put one in. Zero issues. The trucks run smoother. And the lifters aren't getting beaten to death every single drive. I won't sit here and tell you it's magic. A lifter that's already damaged is a lifter that's already damaged, and this won't un-ring that bell. But it takes away the one thing causing all that wear in the first place. That's the whole game. You don't need a five-thousand-dollar delete. You don't need an expensive tune. You don't need to tear anything apart. You just need to stop the cycling. I'm not writing this for any company. I'm writing it because I'm tired of watching the guys who didn't know pay four and five figures for it. I'm tired of being the guy who has to break the news. I'm tired of knowing that the guys who did know fixed the whole thing for the price of a tank of gas, and the only difference was that somebody told them first. If you drive a Silverado, Sierra, Tahoe, Yukon, Suburban, or Escalade from 2007 or newer with a V6 or V8, you've got AFM. You've got those lifters, and they're cycling every single time you drive. So be the guy who already knew. Not the one I'm scraping metal out of next month. EDIT: A bunch of folks asked, so here it is. The one I put my faith in is FullForce. This is where to find it: https://www.tryfullforce.com/products/fullforce™-afm-dfm-disabler They back it with a 60-day guarantee too. I've handed out more than I can count and not one's ever come back to me. Not one. See less
