Service brake system
Tyler Williams
A common problem for that generation truck is the ground for the abs computer.  It's located on the "wing" that comes off the frame, just below the driver's door.  There are a couple wires bolted to it.  Unbolt them, clean off the frame at that spot, the bolts, and the connectors on the wires, then bolt them back down and cover with some diaelectric grease to slow down rust a bit.
If that doesn't work, then scan for codes.
