On 11/1/2019 at 12:01 PM, Memphis87 said:
But in case anyone’s reads this thread looking for an answer, here are a few issues I found on the forum that cause a noise in the rear
1.) the headrests, pull them out and spread the prongs out just a little to snug up the fit
2.) Make sure your tire jack is secure
3.) The seat belt covers in the c pillars are loose and can rattle
4.) And if your hearing a pop once in a while,  it’s your spoiler on the outside of your car
5.) lastly, check the chain linkage for the rear slider power wire. It presses up against the glass
6.) Check the play in the back seat cushion.
I stuffed a towel in-between the seat back and the window/rear wall and that cured the rattle.  Of course, that's not a permanent fix but it clearly identified the problem in my truck.  Realistically, I'll probably just shove something behind there and leave it at that, but the better solution would be to remove the seat and figure out how to tighten up that connection.
