Do I need to worry about loading an 800 series ATV into the bed. Ive purchased the DGM tailgate support bars to ease the tension on the cables but the inner tailgate skin and maybe even the entire tailgate seems alot less sturdy than other trucks Ive owned. Somebody has had to try this already, I read about someone with a busted weld, whats the story with loading and holding cargo like this ? Thanks    Peter
What is the total weight of the ATV (ATV and fluids)?
With a rider its close to 1000. So driving up the ramp you get all 1000 on the brackets which I think is OK. Where I'm concerned is when two wheels cross over the gate into the bed, that's got to be 500 and then once in, I think the back wheels will have to stay on the open tailgate.These two parts are where I'm most concerned about the inner skin collapsing. Surely there's someone who's had a heavy payload in a situation like this.....
Thanks
So I am not sure total weight I had on the tailgate, but I have had issues with this. I was picking up boards for replacing my deck ( I should have used a trailer) and I had to have over loaded the tailgate.  Now the drive was not far, but when I got home and closed the tailgate it had actually flexed the backup camera/tailgate button assembly out of the tailgate.  Luckily it popped right back in and have had no issues, but these tailgates are definitely not as strong as the older generations.  The load of an ATV will be closer to the support bars you will be using, but I would keep an eye out for tailgate flex.
  • 3 years later...
Well I just had a big issue with mine.  I have a 21 Silverado.  Had noticed since new that any time I loaded anything into the truck with the gate down, my camera assembly would pop out.  Well big issue arose this past weekend while hauling my snowmobile.  The side of the gate broke a weld due to the machine sitting on it.
Bummer... I expect we will see this more often. The tailgate is a prime candidate for weight savings engineering. I've never witnessed a failed tailgate on a square body or GMT400. GMT 800s the cables would break.
Seems like early on they were 'over engineered' because some loads would inherently be placed right on the end during loading or unloading. As trucks became used less for load carrying that safety margin becomes less relevant. As a percentage of users those loading the tailgates like this are negligible.
I'd bet a tailgate from a 92 model truck could hold more than from 2022 - I'd bet 500 lbs more... any takers?
Another big issue is that the tailgate is not removed easily due to power latch and camera, etc.
When loading heavy pallets on older trucks, the tailgate was easily removed so a forklift could set the load onto the bed, NOT the tailgate.  ...The forklift could then push the pallet further onto the bed.  ....Heavy loads placed on the tailgate only strained the support cables, not the tailgate itself.
I bought my truck as a WORK truck.  ....Many of the "features" make my work more difficult.
While the trend is to raising the height of these trucks, the tailgate height of my '21 W/T is 4" higher than my '88 or '98.  ....That makes a huge difference when lifting heavy objects.   ....Bed sides are also higher which makes reaching over the sides almost impossible (I'm 6'-1").  ....Certainly not conducive for a WORK truck!
    • More is cylinder deactivation. Kia-Hyundai Ive had 4. The warranty is the same 10 years 100K miles. My grandson drives the first one 05 Elantra GT. My wife drives the second one 2011 Genesis. The Genesis still performs as new and looks great. The Elantra looks rough. He’s not kind to it. The third was a Genesis coup. The fourth was a Santa Fe. Those were my daily drivers. I don’t keep them long. Kia is the same as Hyundai with the same warranty. I looked at the K-4 today. Too small, otherwise pretty good buy. Most of Hyundai and Kia’s have a performance upgrade.
    • Thanks for the point of reference
    • Great question. Answer....depends. One the volume of the crankcase, the driver that will actually be using the vehicle and the amount it uses plus the distance expected for that next trip. Couple of for instances:   Wife is going to drive Dizzy to Moline and back plus a bit around town so say 500 miles on the day. I know from years with that SUV that around town and local rural it uses about a quart in 1250 miles. But on the Interstate and her at the wheel without her anchor nagging her she'll push it and it will drop a quart in about 800 miles. Hence, around town I wait to somewhere between a quarter down to a quart down. On her trip I'd top it if it was down a few ounces and hope for the best.    Have I overfilled one? You mean by adding before it needs a full quart I assume. No, not once after finding the true fill mark.  I know the dipsticks of everything I drive and add what it needs. I learn this by doing the first oil change a quart low. Run the motor for a few minutes. Let it sit over night. Check and mark. Then add half a cup at a time making note of the place on the stick. I add through the dipstick tube with a barbeque basting bottle. Give it a few minutes to drain down and check again.    A vehicle like Dizzy that uses this much oil will take a few quarts between 3K changes. I keep one in the vehicle with the bottle and a bag. (Mindful of it's fullness) Not a big deal and never makes a mess of it. There is no such thing as "multiple quarts' in my shop for any specific oil. There will be a maximum however of the number of different oils used over the fleet.     Dizzy holds a nominal 5 quarts. So the first fill was indeed over as it actually took 4.75. My vehicles are fit with Valvomax valves so I can meter an ounce on the drain if need be. Found her mark first crack at it. Never to be repeated.    Pepper uses none between changes so I don't keep a quart in that one. Straight up 6 quarts put her dead on the full line. Check it ever fuel stop. They will surprise you when they start using.    Raven holds 3 liters or 5.44 ounces over three quarts. I add 3 quarts and 6 ounces. That gives me 5 oil changes on my orphan quart.    Lawnmower holds about 3/5 of a quart. I don't over fill it to prevent an orphan. So yea, depends.
    • 185k on original 6.2L engine and 10 speed. 6" lift with 35" tires. Changed oil (Mobil 1 synthetic) when truck told me to. Original tranny with original fluid and no service or flush done. All highway miles. A/C compressor replaced at 155k. Oil cooler line replaced at 180k. Still daily driver. Love this truck.   This is my 3rd 6.2L vehicle (2008 Yukon Denali / 2018 Cadillac Escalade) with over 150k miles and no issues. Denali had broken motor mount at 100k.
