Ported L86 Intake Manifold - Options
kgkern01
As a few others on here are doing as well, I am trying to maximize the bolt-on potential of my 6.2 L86.  Street driving/daily and towing is my use, so low-mid-range hp/tq and efficiency gains are my goals, not peak hp, I have a highly modified TransAm for that.  On my list is porting the L86 intake, however I haven't seen much online regarding it.  I have found only 2 places so far online that do the porting, Pace and Gwatney, and was curious as if anyone on here has experience with having the L86 intake ported, and other possible porter options, price, results, etc.
pray performance, he’d be my first choice
active on the camaro forums and made a good name for himself porting lt1 intakes
Gains will be minimal from porting the intake.  After your brain got done tricking you I’d doubt you’d even feel a difference.
you want real gains you need to do a gear swap or power adder.
I'm not looking for the maximum performance gains or the most gains that I can "feel", I'm looking to maximize the stock longblock's efficiency and power/torque.  I've seen a lot of dyno graphs on the LT1 intake being ported on stock engines gaining a consistent 10-15hp/tq across the whole curve, and a couple hundred $ isn't too bad to gain this, especially since I plan on pulling the intake to clean it and the valves when I add a catch can anyway.  10-15hp/tq under the curve here, and another 10-15 there, etc add up.  My plans for it are Volant CAI (already have), E85 conversion, stainless LT headers, ported intake, catch can, then dyno tune once all these are done.
3 hours ago, L86 All Terrain said:
Dremel tool.
I don't have a problem going this route if anyone has done this and documented what needs to be ported out on these particular intakes.  I know there is a ramp in/before the ports, and some material behind the throttle body that can be removed, but that is all I have found so far.  Like I said I also don't mind spending $300-ish to port mine by someone with more experience and has done some flow testing, if I can gain 10-15 average under the curve on it.
Lol!!!
volant cai $300
E85 conversion$200
LT headers $500-900 (depending which u go with)
y pipe $200-400
ported intake $200-300
catch can $150-250
custom dyno tune $500
thats $2050 on the low end and $2850+ on the high side.
guys in here have gotten gear swaps done for $1850-2500 including myself at $2250.
I don’t know what you’re towing but a geared, stock 6.2 will out pull a full bolt on 6.2 all day. My geared 5.3 would out pull your bolt on 6.2 all day.  You say your not looking for max power but what do you think the outcome of those parts and a custom dyno tune are going to get you?  Your tuner will try to get as much power as he can safely. Tell your tuner you just want max tq and not hp and he’s gonna look at you like your from Mars.
Lt headers are over kill and the gains aren’t worth the cost imo.  Same with porting the intake. Unless your forced induction the gains just aren’t there.  Gears will make your truck feel like you gained a couple hundred ft/lbs and make the engine/trans combo run way more efficiently, especially the trans.
I’m only posting because you said you use the truck for towing (as do I). Bolt on parts and a tune will improve things sure but not by much. But again I don’t know what you’re towing. If you’re just hauling some boat back and forth to the lake then some bolt on parts will fit the bill. If you tow close to the max like some of us do then gears is the way to go.
either way good luck with whatever you decide. I’m already jealous you got a 6.2.
youtube it, lots of vids on there.
the high flow ones cut out the bottom of the manifold  to get rid of material inside I assume, then seal it back up after the job is done, i think there's more power in running the e85
Lol!!!
volant cai $300
E85 conversion$200
y pipe $200-400
catch can $150-250
I’m calling bullshit
post up a video
heres my bone stock 6.2 with a tune
14 hours ago, Jacoby said:
Lol!!!
volant cai $300 Already have
E85 conversion$200 Doing this anyway, to be able to run $2.20 E85 over $3.30 93 premium, plus the cleaner running and power benefits.
LT headers and y-pipe $500 (Speed Engineering stainless)
y pipe $200-400
catch can $150-250 Also doing this anyway after cleaning intake and valves to keep further deposits and oil out, cleaner running.
custom dyno tune $550 Benefits are more than just the power and torque.  Will also allow me to run E85, run more efficient, and the transmission tuning.
I'm familiar with the difference that gear changes will do, I have done different transmission and axle gearing in my TransAm based on different setups I've ran.  The gear ratio change effect is not what I'm looking for, I don't pull near max load, more like the 4-6k lb range when I do.  I've also driven a 3.42 geared 5.3 on E85 and my 3.23 geared 6.2 is still noticeably stronger.  If I were pulling closer to max load then I would swap the 3.23 for 3.73, but I only pull half of max
More hp and tq under the curve and slightly better mileage and sound for $500 works for me, I'm not going to go expensive with the headers, its not worth it to.
This is what I was asking about in this thread, if anyone else has any experience doing this on their 6.2, and maybe a before/after dyno with it.  I know the 5.3's pick up some power with the 6.2 intake/tb swap.
I would LOVE to put a twin-screw Whipple on it, but I'm not trying to get out of hand with my truck, I have the car for that haha.
from thier dyno numbers I'm only seeing gains up to 3000rpm,  most of this is probably due to the larger throttlebody not the manifold,  but you need the l86 manifold to install larger tb
yeah order from amazon or rockauto, you'll need the o-rings and tb gasket, and  do a tb reset afterwards. its a weekend job and the mounting clip in the rear I hear is a real bitch.
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
