Thanks for clarifying. Would you agree that the Alaskan edition would be the best suited if you are ordering a plow truck?
15 hours ago, MTU Alum said:
Alaskan does not come with plow mount.  Chevrolet teamed up with boss for that media event.
#iworkforGM
The Alaskan just gives u the same packages u can pick with a regular order and u get a decal put on the bed of the truck....not something I would want
Sent from my Moto Z (2) using Tapatalk
  • 11 months later...
I was wondering what the wiring harness does to help the electricial situation on a 2020. <y secondary battery keeps going dead after about 40minutes, chevy forgot to install harness so took it in to have it put on. But I dont think it would help? It says it helps only with black out on the center screen. But Boss says it will help with battery issues? I have the dual batteries with the 220 alternator without the second alternator, maybe that was a mistake.
On 11/28/2019 at 8:16 AM, deluter said:
Just got the plow all set up on the new beast!
I was surprised at how very little they had to cut into the air dam on the front. Front end design is much more plow friendly when compared to previous generations. I also can't even see the plow lights over the hood because the truck is so tall.
Bring on the snow!
2020 AT4HD 6.6L Duramax Dark Sky Metallic
Boss DXT 8'2"
Any pics of the front end with the plow mount only?
  • 10 months later...
On 11/28/2019 at 11:23 AM, L86 All Terrain said:
Nice unit man. Those stainless plows are nice and light. I have stainless 8' Fisher XT V-plow on a 2015 Silverado with a Truck-Craft aluminum dump bed/sander. Just ordered a Caterpillar 950M with a 12-18' 6-way AMI plow with the new "fluid edge" which should be ready for pick-up tomorrow or early next week. And I have a 2015 John Deere 644K with a 12-18' AMI plow and snow tires also. I have over 20 contracts for this year for plowing and sanding. If anyone needs and help or questions with snow removal work I would be happy to help you out.
Boss 8'2'  Stainless is actually heavier based on BOSS web spec sheet::   Poly: 795 lb      Stainless :  823 lb      Steel : 785 lb
 https://www.bossplow.com/en/products/truck-equipment/power-v-xt-plow                                      Here's my 2011 Sierra 2500HD w/8-2 boss VXT- bought a 2019 GMC 3500HD last year and put the mount on it so I could use plow on  on either truck
Edited by Steam
add pic
I was going to put a Fisher on my 2023 Denali until I found out how much of the bumper would need to be cut off to make it work... I started to notch the valance... Until I realized how much cutting would be needed to get the MM2 plow frame on...
Edited by Brendan Stewart
Why on earth would you think it was a good idea to put a plow on a Denali 1500?  No plow prep, and they have those active shocks.
  • Haha 2
From his profile background picture, looks like a plow may be connected to his 1500. I'm speechless 🤣
Ok hard dude. People put plows in 1500s all the time. I don't have a business. It's for my own driveway.
They do, but you've got the wrong 1500 for the job.  A more money than brains scenario here rather, the 85K truck that by no means is set up or intended to plow with.
    • Your safety is of utmost importance, @joshua1221, and we understand the importance of having all your lights working in your truck. If you have not already, we highly encourage you to bring your concerns to the attention of your local GM dealer. They are in the best position to diagnose your concerns as well as confirm the compatibility of the mirrors with your truck. Additionally, we would like the opportunity to explore any way we may be of assistance. When you have a moment, please visit: https://s.gm.com/support-request and fill out the support request form with all pertinent details. This form helps our team gather the right information and ensures your request is routed appropriately.
    • - I like the outside but not as much as the Chevrolet.  They ICE'd the EV styling and it works, but I think exterior goes to Chevy on this one.     - SLE and SLT dead = Not.  Surprising.  Fits into the rest of the GMC lineup like this which (aside from Pro) matches the rest of the family.  Elevation, AT4, Denali.     - Interior.  Sophisticated Malaise era.  Why do I say Malaise?  Drawn with a ruler.  Rectangles everywhere.  Looks very premium though.
    • I may be old school. But I’ll pass. I’ll stick with the old stuff. Thank you.
