Dual or Single battery Stereo setup.
jgadget
Nope its the jumpseat. 4x shifter on the floor. There might be space under it idk. I didnt check when i had it out last.
Sent from my LG-G710 using Tapatalk
Ah ok
I have the bucket seats in the front no Bose truck. Tons of room under there. Very easy to get wires in there.
  • Replies 41
I hear the alternator is controlled by the bcm. I wonder if theres a way to program for better charging. Maybe wams can do it?
US alternators makes a PCM controller but it doesn’t work with the new four pin Gm plug as of yet
You mean 2 pin on the alternator?
Maybe I’m mistaken
Does our trucks have the 2 pin? I was under impression they were the 4. If they are 2 then I believe the us alternator pcm module will work.
Maybe I’m mistaken
Yep our trucks have the 2 pin alt. I think the 4 pin was a body style or two ago.
Well then! Lol. I didn’t even go look in my truck hah
I believe it will work then. They are backordered untill January. They make 2 models. One with fixed voltage. One with adjustable.
Im looking into them now. I really think that module will do the job. For some reason I'm thinking there's more to getting the charging where it needs to be then a simple alternator swap. Im thinking the alternator acts like a light bulb and the regulator the dimmer switch. Meaning it generates the same output based on what its told. So im thinking what ever factory control commands it wont do as needed. Hence reason someone made that regulator.
Looks like I'm adding another item to the list.
I agree!! I will be ordering that as well.
Yeah im gonna pick this up after I swap my start batt and get an isolator. I bet the stock alternator will handle the load. If not I'll step up to the 220a 3500 alt.
    • Thanks!  I figured as such; GM and other manufacturers have used standard parts and harnesses across trim levels and such for decades.  I pulled the blank accessory cover off of my commuter van (a 2016 or so Chevy 15-passenger) years ago and found the plug for a USB outlet.  It wasn't connected to anything, though (I tried swapping in an outlet from another van).  I was a GM Tech years ago (late-90s) and was pretty familiar with my 2006.  I might be wrong, but I view newer vehicles (pretty much anything made in the past 20 years) as being a lot more plug and play.  Meaning, more unused wires and plugs unless you have the Mack Daddy of vehicles.
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
