4 wheel drive whine noise
Chappy239
When driving along in 2 wheel drive, and I turn the dial to AUTO or 4 High I hear this kind of whining noise. If I take my foot off the gas, it mostly goes away. Shift back to 2 wheel drive, and the noise stops. Is this possibly a transfer case issue?
Currently my truck has just over 74,000 miles. I have had it since new.
Mine does this too and always has.  I believe it's normal.  You're just hearing the chain in the t-case when it's engaged because it's basically right under the center console area.
Wait, you can change to Auto or 4WD while moving and on the gas?
I always change before going into drive or if need be, change it while coasting.
It may be worth while do change your fluid and also look at the magnetic plug for shavings. Better be safe...
Youtube the fluid change, its pretty simple.
Yes, I switch to 4 wheel drive on the fly, but not under load.
I will check the transfer case fluid, etc.
Wait, you can change to Auto or 4WD while moving and on the gas? I always change before going into drive or if need be, change it while coasting.
If I remember the manual correctly it says you can change I to 4hi or 4auto at any speed. I do so all the time without issue. I don't always coast, but I'm not into the throttle either. Basically, just steady speed or off throttle and I've never had a problem.
For 4lo, you have to be basically stopped or moving less than 1mph. The truck won't let you go into 4lo at anything faster.
Sent from my SM-G892A using Tapatalk
When the last time the fluid was changed.
My noise went away after new fluid.
Sent from my SM-N976V using Tapatalk
Seeing as how you say under acceleration and in 4x4 only, it could be a pinion bearing in the front diff. Pull your front diff plug next time you are working on it and check for metal. I have changed one on my plow truck 50,000mi. As others have stated there is a slight noise/vib from normal operation but if it is severe enough to annoy you, there could be bigger issues, especially on a 2014, how many miles do you have?
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
