2014 Silverado eps fail= crash.
Robert Hansen
Hi, just found this site on a google search.  I have a 2014 Silverado 1500 double cab 4x4.  Bought it new in early 2014, it now has just over 100k miles on it.  About 3 weeks ago I was leaving my house going down an ice covered hill around a 90 degree left hand turn when my steering just locked up. Couldn’t do anything.  I hit the brakes but we all k ow that is useless on an ice covered hill. I hit a tree at approximately 7 mph right across the right front headlights.  Damage is now at $9,746 and the body shop found a trouble code for power steering failure.  My insurance doesn’t believe me, so I’m fighting them on it,   It is almost done with body work then it goes to the Chevy dealer for diagnosis of the steering problem. I had the power steering recall done in 2018 but it appears it didn’t fix it.  Any ideas on how to proceed???
Make darn sure you get that rack and pinion steering replaced. Imagine if you were going 20+mph. Smh. Imo the rack and pinion steering is not meant for these trucks.
Welcome to the site, sorry your first post is a pretty bad one.
They should be able to retrieve any code that has been present for you (the dealership). That should be proof enough with a printout showing it, you would think.
  • 3 weeks later...
I don’t understand why the insurance company would care if the steering locked up or didn’t lock up.
If he never spoke up about it they would overlook it and it wouldn't be considered for replacement.
Sent from my LG-G710 using Tapatalk
It’s because now the insurance company says the accident was my fault and will jack my rates up.
Anyway, an update:
total for repairs came to just shy of $11,000 for a 5-7mph crash.  The body shop took my truck to the local Chevy dealership who has done all of the routine maintenance and all 16 recalls on my truck. They looked it over and say the cant find anything wrong. All is good to go.  So I pick my truck up and within a mile the right rear blinker goes out. I go to autozone and get a bulb. Replace it, all good.  Then yesterday (not even 2 weeks after I get my truck back) I go to start it and nothing, zilch.  No power period.  I take the battery cables off, clean them even though they look pretty good.  Put them back on, truck fires up.   Today while driving to Walmart (60 miles away) goong around a corner at 70 mph the truck act’s like U just switched off the engine for about 2 seconds, it feels like the engine has died then takes off again.   I have a feeling that this thing is going to die a horrible death and I hope the seatbelts and airbags do their job.
I'd drop it off to an independent shop let them write it up. Give details on whats happened due to the wreck and show the insurance. Then you can push that 2k+ replacement and have them figure why the engine shuts off.
It's all up to if the dealer or whoever is fixing it can find out what exactly caused it to lock up and if that is good enough for the insurance or if they want the dealer or GM involved. I have heard of it jerking and being hard to turn but never a complete lock up. The insurance company is doing what I would expect them to do if someone wrecked their truck on an icy road.
Sent from my SM-A505U using Tapatalk
The question is, was it an actual lock up or was it the loss of electronic power steering assist that may make it seem like it lock up?
I know how it feels not to have power steering with a traditional steering setup but is it any more difficult not to have power steering with a rack and pinion?
Bash:   Long story short, I don’t have the time, energy or money to fight GM or Progressive so I’m just moving on.    My plan is to dump the truck but I need 2 more years out of it before I do that.
Blain:   It was not like when the steering wheel locks up when the keys are out, It was as if there was an impossibly strong person fighting me over the wheel. I could turn it a few inches in either direction but then It would groan, whine and “fight back”.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
