Hello,
I have the HD camera in back with two views (one straight down at the hitch and the normal one looking straight back.  While driving and selecting the rear view camera for a quick view, I am always stuck with looking at the camera pointing straight down at the hitch.  I can't seem to successfully select the camera looking straight back while moving forward for a quick look.  What am I doing wrong?
Thats the way it is. The hitch view will come up. Now if you have the trailering package on a 2020 model, different story.
Hmmm, somehow I was able to get the rear view camera to come up while moving once, but haven't been able to do so since.  Maybe the system has to detect that a trailer is hooked up....
I find that view helpful when pulling through ba parking spot I hit the camera and keep pulling forward till I just cross the yellow line
Sent from my Pixel 4 using Tapatalk
I’m able to get the rear camera to come up while driving by bringing up the main menu (home button?)and there is a selection for camera (possibly need to scroll right to see it) and the rear camera pops up while driving. Now I just have a LT TB with just the back up camera on the tailgate so I’m sure others have other options.
I was able to do this once as well, but can no longer do so.  All I get now if the camera facing down at the hitch.  The other options are grayed out.
Mine allows me to do this in drive, but I have to be at a stop (i.e. at a light). If my truck is moving, I only get the hitch.
My truck shows the normal rear view while in motion.
Maybe it is model and option specific that dictates the view of the camera?
I can view both while moving. I can switch between the hitch view and the rear view in motion for 8 seconds at a time. I get front view, rear bed view, tailgate rear and hitch.
same here
Yeah I have the trailering  package and my son loves to use it in motion to see "who's at our six" Must be a difference in the HD and non HD camera package.
I wish it was a longer time (15-20 secs would be good) but I’m happy they provided some access while in motion.
I to wish it was for a longer period of time. 30 seconds or just on as long as you want
It's kinda like that annoying warning that pops up and you have to hit ok. The timer is so you don't focus on whats behind you while running into whats in front of you.
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 510 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
