Where is this ground located?  I know there should be two main grounds coming from the battery.  Haven't traced either of them yet.
Edited by BlaineBug
This ground is in the passenger side wheel well. You do not need to remove the fender liner to get to it. I used a wire wheel and adhesive remover. I cleaned it up pretty well when I was done. But you can see that something may have been going on with the ground itself. The other runs to the back of the engine block and looked fine. I may do what someone else did and add another ground to to brake booster. I have not pulled the dash apart yet for the BCM ground. That will be my next step.
That sounds like G141.  Tech found mine to be "full of undercoating" the other day as well.
I'll pull the dash one G218 this week or weekend. looks to be like a 10 minute job to get to it.
"A ground bolt without the proper hardening may not properly clamp/secure the ground eyelet."
What would improper hardening do?  Does this cause the fastener to stretch over time?
I have also heard G141 referenced many times for being corroded or in my case it was undercoated.  How badly it was undercoated, I don't know since I didn't do the work.  Apparently G141 is the only connection between chassis and the battery as G103 is between the battery and engine.
Edited by BlaineBug
Yes from the battery it is only two grounds, one to the frame and one to the engine. Engine looked to be fine. G141 on mine was pretty nasty. I bet only half the terminal was contacting. Lots of undercoat under it and some corrosion.  I tightened it up pretty good. It's still on my list to add a ground from the battery over to the break booster. This would put a direct BCM ground less than 12" from the battery ground. I assume the bad fastener does stretch and allows the terminal to back away.
Just now, BlaineBug said:
Has your issue returned after checking out G141?
I wont know, It happened a couple times like 5 weeks ago on a Saturday dealer had it for a few days couldn't make it do it again and then 4 weeks later it did it and wouldn't start for like 15 hours. Tried it once in the morning then one more time an hour later and its been fine since. It hasn't done it to me since friday night, I had it towed home because I knew it would start. I just cleaned up the ground tuesday and I guess we wont know for a while.
20 hours ago, BlaineBug said:
Just about as sporadic and elusive as you can get.  That's unfortunate.
Well taking the dash apart was very fast and easy less than 5 minutes. Now getting to the ground is another story it’s in an awful spot and but I finally got to it. And yup the plastic was pinched right there. I had to use a shallow well 10mm a universal and a few extensions but I got it off and trimmed. I’m just realizing I forgot to put a harness clip back on that ground but oh well.
Seeing that your truck is a 2014 model I would have thought your dealer would have taken a look at all of the TSBs.  And the TSB regarding this ground G218 is definitely on par for 2014-2015 models for sure.
What's the harness clip that you forgot?
TSB 18-NA-161.pdf
Edited by BlaineBug
It is just a little plastic piece that runs a harness over the ground. I’m sure it’ll be fine. Probably just for assembly/ rubbing reasons.
I think I know what you're talking about.  My OCD would probably have me re-doing it.  By the way there is apparently also a ground under the same location on the passenger side.  Although the BCM doesn't ground there so it hasn't been problematic as far as I know.
Edited by BlaineBug
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
