So I just bought a 2020 3500 w/t with no carpet. I still want to run floor mats. I am just wondering if the factory mats are spiney or have anything that would keep them laying flat on the work truck floor. Does anyone have any experience with this? I tried to search.
I have a set of the factory rubber floor mats for a 19 double cab that I took out to upgrade to the liners and I'd be willing to let go of them easily, and no they don't seem very "grabby"
Thank you, but I just ordered a set of weather tech. The vinyl floors do not have the factory anchor points but the weather tech come with anchors so I thought I would give them a try. The accessories gm website said the only ones that come up compatible for my truck are the carpet mats.
  • 6 months later...
The factory ones fit great and snug.  Then I just made anchor plugs and 3d printed them.
https://www.thingiverse.com/thing:4500576
I know you've already bought the weathertech, but the factory liners are 10X better, with or without the use of anchors.  I would honesty try to return the weather techs, the factory liners are truly that much better.
  • 3 months later...
i have the weather tech ones in my  wt  truck. they come with anchors  , follow the instructions to install the anchors and they will hold  super well.
    • I have changed oil and filter for years by starting a cold engine to warm oil up, let it run 5-10 minutes depending on temperature. Drain until it starts dripping, refill with quantity from owners manual or get it close.
    • I changed the factory fill oil in the rear diff of my truck for the first time today and the miles is close to 9000 on the truck. There was a lot of fines on the magnet, a very thick layer but working it through my fingers it all felt like mush and as most know it appears like graphite, so no surprise chunks anyway. Certainly was time to do it from my thinking and could have been done sooner but the oil didn't look awful but sure wasn't new looking and never expected it to either. I did use some solvent to help me clean out the bottom area of the axle housing, just get any other stuff settled at the bottom washed and wiped out of the housing for the bit of effort it takes. I used Amsoil Severe Gear 75W90 in the easy packs to try out what they are like and I used up 4 packs and didn't spill much at all in the process but did take all four of the packs and go to the work bench and emptied them into a measuring container and there certainly was some in them that added up to something, then poured that into one of the easy packs and squirted in what I could get out of it. I would say the level is within 1/8th of an inch of being level with the threads at the fill plug so just the perfect amount. Once again, more than what GM says the fill volume is but computes with what others are adding to their rear diffs as well.
