2014 GMC Sierra 1500 5.3
226000kms
When accelerating from an intersection today, I got a flashing CEL and 'Cylinder 4 Misfire' code.  Only lasted for 10sec or so and went away.  Truck runs as per normal.
Do I have a pending problem here or just a fluke?
To me there is still a possible problem.
I would at least check the plug wire and pull the spark plug to check the condition. A scan tool is what I'd use to look into it more, logging the live data of misfires to watch and see what it's doing.
I agree with CamGTP. Try as well to use injectors cleaner, you might have bad oxygen/fuel mixture at the combustion chamber
Just injector cleaner do anything with DI?
I mean if something clogged it with 2900psi, it probably doesnt desolve easily at all
Edited by truckguy82
Our vehicles are direct injection, they are exposed to contamination from gases and oil oxidation. They need to be regularly cleaned to ensure they are not clogged. Non DI is at least better since they are not inside the combustion chamber.
Using CRC or Seafoam valves cleaner helps as well. Bad or non clean fuel can cause problems as well. But I would totally agree with the need to check wires, spark plugs, and coils as mentioned or less cost fix firstly.
Unfortunately these new engines use technology that is hard on engines and especially oil.  Active Fuel Management, Dynamic Fuel Management, start stop, variable vavle timings, turbo charging, ecoboost etc. All these new technologies put a lot of stress on the oil.   Not all oils are up to the task and that's why GM and other oem's have been pushing for better oil specifications to be developed.  Yet there are a lot of oil companies who continue to market "good enough" products and customers who refuse to spend the money continue to buy these "good enough" products for their expensive vehicles/engines. They think frequent oil changes are cheap insurance but in reality, cheap oil is the problem.
Why do you think some oils are cheaper? Where do you think they cut the corners? Did they use cheaper oil base stocks and additive packages? Less highly trained engineers? Did they cut back on quality control? How can they afford to spends millions of $$ on advertising and still make money if they claim their oil is best?
226000kms
Was there any other codes besides the misfire?
Couple possibilities.
Fuel injectors have been a thing lately on 2014-2018 trucks.  This would ideally require a fuel injector balance test.  The fuel trims on bank 2 might be a starting indicator of there being a bum injector however.
AFM.  A lifter failure could be possible, but if you don't have a hard/permanent misfire, its not likely that.
Source?
i’m aware of the carbon buildup on the valves, but I’ve never heard of injector cleaner being necessary.
it’s 2900 psi of fuel.
carbon deposits are tough, but they are no match for a gasoline pressure washer.
I’m pretty sure the only thing clogging the injectors comes from within the fuel tank. But I’m just speculating with no real research.
36 minutes ago, truckguy82 said:
Source?
It's the tip of injector that is problem....These tips must be maintained meticulous in GDI's  so that the the holes never change shape,size with resulting spray patterns.  So what you do 3K oil changes, this, that or the other thing....This also needs to be done with GDI's
Keep em clean boys and they keep you out of trouble!
Edited by mookdoc6
Source?   i’m aware of the carbon buildup on the valves, but I’ve never heard of injector cleaner being necessary.
Although that the pressure is very high inside, carbon can still build up since you are not using the vehicle at full power all the time, and when you turn it off and lit it sit it can start build up. Cleaning regularly and perhaps using a catch can an help a little.If the high pressure cannot help by it self with the additive, probably injectors can be taken out and be cleaned at the ultrasonic cleaning machine.
Check the video at 14:50
Check as well this image from the owner’s manual, it talks about Fuel Additives.
 Here’s the plug out of cyl 4.  How’s it look?  Could it be my problem?
Well, it has what? 140,000 miles on it? Doesn’t look all that bad, but the gap maybe looks a little big (which will happen with mileage). Definitely worth changing - I’d say 70% of misfires are going to be something simple like plugs.
Got to say, I too had a misfire with the flashing check engine light. Lasted about 10 seconds, never came back but I do feel a misfire once in a while when going up big hills on the highway at lower speeds. Cylinder 5 misfire. Only 45,000 miles when it happened. Plugs looked great.
Edited by Doublebase
I was starting to get a misfire, also it was like my truck hit its rev limiter at 4k. I've been looking around on here at different issues. I think mine is fuel system related. It backfires once followed by being sluggish. With that being said today was the worst. I dropped it off at a local shop. Ill know more tomorrow. Good luck to you all.
Well that sucks. It was back firing through the intake. It had a tick this morning it had never had before. Its definitely a lifter. Mechanic will start tearing the engine apart tomorrow. Its not good boys. Looking at 2-3k.?? The mechanic is also going to do compression test before tear down.
Replace all plugs and wires if they are stock, at that milage you should have changed them already.
Then run SeaFoam FUEL INJECTOR cleaner, not the seafoam cleaning procedure but that will also help you im sure.
SeaFoam fuel cleaner in those small bottles is what fixed my clogged injector misfire issue, no other cleaner helped. Run 2 per tank at least 2 tanks.
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
    • Trust me I appreciate the comments and concerns. It's what I was looking for to help me evaluate the situation and what I want to do. I have decided to move forward with the BORA hubcentric slip on 3/8" (.375") with the extended lugs nuts. Fedex says they should be here Monday :). Meanwhile, the dealer got the remote start and Patriot spray in bed liner done over the last couple of days. Also, I installed an inline stop/start eliminator today. Starts back up in what whatever mode you shut it off in, so you don't have to hit the button every time you fire up.
    • $2.20 E-85 down from $2.59 Around $3.80 for regular and about $5 on average for Premium.  Propane $3.99 a gallon.
